help...i need somebody(weird clikkity clank)......
Old May 16, 2005 | 06:50 PM
jammin civic's Avatar
Default help...i need somebody(weird clikkity clank)......
whenever I turn my wheel too far to the left or right i hear like a popping noise and im not sure what it is, Also, whenever i go over a bump i hear some clikkity clankage from my car, but i just replaced my shocks last summer(kyb gr-2's) and i have skunk2 coilovers...can someone help?!?!
Old May 16, 2005 | 07:06 PM
Del_Sol_Si's Avatar
check ur axles yet? had the same problem with my DA
Old May 16, 2005 | 07:08 PM
hatchling37's Avatar
Default Re: (Del_Sol_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Sol_Si &raquo;</TD></TR><TR><TD CLASS="quote">check ur axles yet? had the same problem with my DA </TD></TR></TABLE>That's what it sounds like.... Which way do you turn when it does the clicking?
Edit: Reread your post. Both ways and it clicks?
1995Ex_Sedan's Avatar
Check your CV Boots, They may be torn/ripped. This can cause that tapping noise while turning. Its normal over time. If you dont know they are the little rubber cone shaped things on each axle next to the wheels.
Old May 16, 2005 | 07:15 PM
JDM EJ1 95's Avatar
mine does the same thing... but mostly in reverse... ive never really heard it driving normal.. and its not a small click like an axle its a... POP! i dunno kinda wierd... tie rod or something.. gotta check it out
Old May 17, 2005 | 04:41 PM
Default Re: (JDM EJ1 95)
yea....each way i turn it it does a loud POP
Old May 17, 2005 | 05:28 PM
hondaracing1's Avatar
Default Re: (jammin civic)
had the same problem...replaced both my cv axels and it still made this noise so im guessing its the tranny about to take a **** on me
Old May 18, 2005 | 08:03 AM
Default Re: (hondaracing1)
bump....still need help!!!
whp
Feb 3, 2007 08:13 AM
SomeDude56
11
Sep 16, 2006 02:08 PM
pr0phet
Nov 3, 2005 12:32 PM
.Grimace
Sep 11, 2005 05:08 PM
ganjafarmer143
19
Aug 15, 2005 02:14 PM
