for you h22 owners. (intake manifold)
B A N N E D
From: los angeles, Eagle Rock, CA, united states of america
on the stock intake manifold it comes out in 3 parts. im wondering if its ok to not run with any gaskets from where the cold start is (middle peice of the manifold)???
i broke it taking the manifold apart
anyone know what this part called? and #?
Modified by BaNAnABoAt689 at 9:41 PM 5/16/2005
I wouldn't do it because, this would probably lead to a bad vacuum leak. The leak would cause the un-metered air to lean out your mixture, and probably give you a higher idle
. I would just get a new gasket if you are able to
SpeedFactoryRacing
Performance
130
Apr 12, 2013 10:30 AM
