Primary Heated Oxygen Circuit
Old May 16, 2005 | 06:15 PM
fade22's Avatar
Default Primary Heated Oxygen Circuit
Well, after work one day I was cruising along about 55mph or so, and all of a sudden my CEL came on. I've been really busy, but I searched and learned to check the code and all of that. When I pulled the code, it blinked 1 time, and from the chart located http://hondaprelude.to/article....html
at the site, it means Primary Heated Oxygen Circuit, or the ECM is the culprit. My question is, what are these things? I searched for each, and all I found was someone looking for an ECM. Anyone know what it is and if I should attempt to fix it myself or what? Any help in the right direction will be greatly appreciated.
Edit: This is on a 97 SS
Old May 17, 2005 | 08:29 AM
boomslang's Avatar
Default Re: Primary Heated Oxygen Circuit (fade22)
Your primary O2 sensor is probably going bad (the heater circuit of it). If the CEL persists, replace the sensor.
Old May 17, 2005 | 09:33 AM
fade22's Avatar
Default Re: Primary Heated Oxygen Circuit (boomslang)
Thanks, I'll be replacing it within the week and I'll let you know if it worked.
Old May 17, 2005 | 09:45 AM
IHateJDM's Avatar
usually code 1 is for the o2 sensor itself, and 41 is for the heater circuit. If you want a short term fix, take it out and spray it with carb cleaner. It'll buy you some time.
nwarp
Jul 17, 2004 06:01 PM
HYBRIDHATCH92
Aug 15, 2002 03:52 PM
Qwikrex
Jul 29, 2002 10:46 AM
Qwikrex
Jun 22, 2002 12:52 PM
Qwikrex
Jun 22, 2002 01:04 AM
