Honda S2000 Honda S2000
NA Questions
Old May 16, 2005 | 04:28 PM
Moemers's Avatar
Default NA Questions
ok, so after considering everything, id really like to go all motor, cause i mean really, its just bad ***. im not planning on going too crazy, i wanna drive it everyday, but my question was, what should i do. I was thinking of pretty much everything, cams(with cam gears and valves and springs) pistons, rods, stuff like that. i also have a VAFC, but i think i might as well go AEM EMS or GReddy EManage. i dont know, if anyone can help and give me advice as to how to go with a reliable all motor set up, id appreciate it, thanks
Old May 16, 2005 | 04:39 PM
WowOzYouRock's Avatar
Default Re: NA Questions (RWD_Honder)
ur budget!!!?
Old May 16, 2005 | 05:20 PM
BOOSTEDS2K's Avatar
Default Re: NA Questions (Y2K_S2K)
YEA .. HOW MUCH YOU LOOKING TO SPEND??
Old May 16, 2005 | 07:49 PM
Nishant's Avatar
Default Re: NA Questions (BOOSTEDS2K)
any hp goals?
Old May 16, 2005 | 10:29 PM
Moemers's Avatar
Default Re: NA Questions (Nishant)
im not looking to spend anything too crazy...maybe like, 2-5 grand at the most? hp goals are nothing, maybe get it up to where it should be at 240, but i dunno, lets just say 2-5 grand, no hp goal
Old May 17, 2005 | 05:01 AM
Young_R's Avatar
if you are going to do internal motor work its going to COST more than 2-5k.
try more like 8-10K.
even if you just get intake, header, exhaust w/ AEM it would cost more than 5k plus tunning.
but it is possible to make 240 whp with just that.
Old May 17, 2005 | 08:56 AM
Francesco's Avatar
Default Re: NA Questions (Young_R)
a stroker kit alone is your budget...
I/H/E you can swing...Building the head gets expensive also...
Old May 17, 2005 | 09:02 AM
Default Re: NA Questions (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">a stroker kit alone is your budget...
nooo way!! ... its gonna cost him more than 5 G's ... think about the labor
Old May 17, 2005 | 09:40 AM
hypnosisracing's Avatar
lol...with a range like $2,000-$5,000, it sounds to me like you need to think about this a little bit more. Not that that amount of money isnt enough, but its a LARGE range, you can do ALOT more for $5,000 than you can with $2,000...n/a wise though, expect to spend alot more to make the kind of power i think you have in mind.
Old May 17, 2005 | 11:13 AM
CNS2000's Avatar
I think that if your budget is around 5k, you might get more power from a S/C than going NA. Unless you defenitly want to go NA and tha's it. But for me the S/C will make you run faster and is just a bolt-on-kit.
Good luck!!
Old May 17, 2005 | 11:23 AM
MaxGeek's Avatar
Get rear gears, yellow box(speedo correction) and reinforced differential. Probably ~ $1400 after labor. 4.44 , 4.57, 4.77 are your main choices. 4.57 would make your car about .4 secs faster in the 1/4 mile. One the track though it depends on how its layed out if you will be faster or not. Sometimes gears can be a disadvantage in autox.
Old May 17, 2005 | 11:32 AM
Default Re: (MaxGeek)
if you have 5 G's ... get I/H/E and aem ems and ure set ... J's intake , toda header, spugen single outlet exhaust
Old May 17, 2005 | 12:38 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxGeek &raquo;</TD></TR><TR><TD CLASS="quote">Get rear gears, yellow box(speedo correction) and reinforced differential. Probably ~ $1400 after labor. 4.44 , 4.57, 4.77 are your main choices. 4.57 would make your car about .4 secs faster in the 1/4 mile. One the track though it depends on how its layed out if you will be faster or not. Sometimes gears can be a disadvantage in autox.</TD></TR></TABLE>
I would go with this advice. In fact if I ever modded my S2K it would be with the Rick's 4.57 gears. Right now my project car is the Civic, so I don't have any money for the S.
Old May 17, 2005 | 12:44 PM
Nishant's Avatar
Default Re: (RyanCivic2000)
with a 5k budget? I'd do gears, IHE + AEM EMS. may go over a lil but thats would be the set up
Old May 17, 2005 | 01:15 PM
Default Re: (Nishant)
J's intake = $1200
Spugen Ti = $700
Toda header = $1200
AEM EMS = $1300
do the math .. i round off everything
Modified by Y2K_S2K at 4:26 PM 5/17/2005
Old May 17, 2005 | 02:46 PM
Mr. Lucky's Avatar
Default Re: (Y2K_S2K)
the t1r 70mm ever come out yet?
Old May 17, 2005 | 02:51 PM
eMpAtHy's Avatar
Default Re: (bs-inc.s2k)
1200 is a little too much for an intake. well, 2500 is a little much for the dual amuse R1 exhaust..****, everything is expensive for the S
Old May 17, 2005 | 02:53 PM
RyanEJ8's Avatar
Default Re: (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">1200 is a little too much for an intake. well, 2500 is a little much for the dual amuse R1 exhaust..****, everything is expensive for the S</TD></TR></TABLE>
I agree. $1200 is too much. I would just look into the K&N FIPK.
Old May 17, 2005 | 02:55 PM
Mr. Lucky's Avatar
i've seen some people running the arc box with the chamber. how's the performance on that? other than people saying heatsoak. any pros?
Old May 17, 2005 | 07:50 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bs-inc.s2k &raquo;</TD></TR><TR><TD CLASS="quote">i've seen some people running the arc box with the chamber. how's the performance on that? other than people saying heatsoak. any pros? </TD></TR></TABLE>
everyone says heatsoak...but everyone running it says they feel a gain and have no signs of heat soak...
Old May 17, 2005 | 08:00 PM
Nishant's Avatar
Default Re: (Francesco)
cheaper route but it works:
intake = comptech
header = j's or spoon
exhaust = t1r 70mm (whenever it comes out)
those there add up to about 2200-2300
get AEM EMS + Tuning. spend rest of gears
hondakook
21
Feb 17, 2012 08:18 PM
Gotta_get_a_Teg
Oct 14, 2004 04:53 PM
CrazieLude
Oct 11, 2003 12:12 PM
slacker1.
Sep 30, 2003 12:01 PM
loooong69
42
Sep 29, 2003 02:35 AM
