Wacky SiR Gauges
Old May 16, 2005 | 02:59 PM
pulse_crx's Avatar
Default Wacky SiR Gauges
Hey, just tried to install my SiR gauges, and they seem to be having issues.
*i have searched many of times*
For the start, how did you guys wire up the electric vss? Do you need to run it to the ecu? My signals are the next fucked thing. When I signal left or right, my tach needle ticks with it. Also when my 'brights' signal light and my turn signal indicators are always lit up, when I turn on the brights, the tach goes down. Let me know if anyone has ideas. I followed the wiring diagram for the crx. I have crx Sir gauges going into a 90 si hatch. Any help would be wicked.
*Also, dash/cluster lights havent worked for months, checked fuses and bulbs.
Old May 16, 2005 | 04:58 PM
tc_gts's Avatar
Default Re: Wacky SiR Gauges (pulse_crx)
first off who wired it up?
did you do the correct wiring...
wut kind of SIR is it a 4plug cluster from japan?
and the vss is electrical so you need an electrical VSS in your tranny...
and yes b-16 is the wire that revices the signal from the VSS to the computer and it also goes to the cluster...
urafag
May 14, 2006 12:39 PM
Power Rev Racing
Sep 12, 2004 06:58 PM
c for sea
10
Mar 26, 2004 11:01 AM
Starbucks_91b16acrx
Oct 10, 2003 08:54 AM
