LS SWAP/HEADER DOESN,T FIT
Old May 16, 2005 | 02:27 PM
SCIVIC94's Avatar
Default LS SWAP/HEADER DOESN,T FIT
I just did a ls swap on my 95 civic four door last night.Problem is my header angles the cat up at the floor and there is a gap about an inch between the exhaut system and the cat.On top of that the bolt holes for the cat don't line up either.I am using an AIRMASS header stock civic cat and an AIRMASS civic exhuast.Has anyone ever had this gap problem or know of a header that will solve the problem?are the integra and civic cats different?any help would be greatly appreciated.
also will i be able to run a jdm integra type r header and keep my ac?
Modified by SCIVIC94 at 3:38 PM 5/16/2005
Old May 16, 2005 | 02:31 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (Senses Fail y0!)
weld?
Old May 16, 2005 | 02:39 PM
tampajason's Avatar
Default Re: LS SWAP/HEADER DOESN,T FIT (SCIVIC94)
deck height is different and you need a different header or a longer cat/test pipe.
Old May 16, 2005 | 04:19 PM
SCIVIC94's Avatar
ANYONE ELSE?
Old May 16, 2005 | 04:32 PM
chad's Avatar
Moderator
Default Re: LS SWAP/HEADER DOESN,T FIT (sxecrow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sxecrow &raquo;</TD></TR><TR><TD CLASS="quote">deck height is different and you need a different header or a longer cat/test pipe.</TD></TR></TABLE>
deck height has nothing to do with this....UNLESS header is not flush on the head.....
Old May 16, 2005 | 05:01 PM
Spence's Avatar
b16 header and you should be good
Old May 16, 2005 | 05:03 PM
918-Hatch's Avatar
Colorado <3
**** it.. Run open header.
Old May 16, 2005 | 05:04 PM
chad's Avatar
Moderator
Default Re: LS SWAP/HEADER DOESN,T FIT (Spence)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence &raquo;</TD></TR><TR><TD CLASS="quote">b16 header and you should be good</TD></TR></TABLE>
a b16 header for a b16 WILL NOT WORK....it is 7 mm short due to the fact the b16 is 7mm shorter than the ls/gsr/b20/itr
Old May 16, 2005 | 05:07 PM
918-Hatch's Avatar
Colorado <3
jdm type r header Will work. If you are having probs making the b16 fit under neeth use a b16 oil pan on the ls bottom end.
Old May 16, 2005 | 05:18 PM
Lmgrcivic's Avatar
Default Re: (918-Hatch)
get a LS cat and that will take care of the gap but there shouldnt be a problem in the deck height of the header to the exhaust unless somethings not lined up right
Old May 16, 2005 | 05:44 PM
SCIVIC94's Avatar
Default Re: (Lmgrcivic)
I THINK SOMEONE JUST FU*** UP WHEN SETTING UP THE DOWN PIPE TO BE WELDED.I GUESS I WILL TRY THE LS CAT.I WILL SEE IF I CAN GET A HOLD OF ONE.
recon23
Jul 13, 2009 05:10 PM
Benhawk
Apr 1, 2007 10:18 AM
jweezy225
Jun 18, 2006 05:34 PM
romoracing
Welding / Fabrication
Aug 16, 2005 10:17 AM
dc2Rgirl
Dec 1, 2004 06:51 PM
