can 16 x 8's fit onb a civic???
Old May 16, 2005 | 01:53 PM
JDMJNKY's Avatar
Default can 16 x 8's fit onb a civic???
what's up guys I plan on selling my auto x's N.I.B, and buying some volks, but they are 16 x 8's and I'd like to know if they'd fit on a civic w/ no rub's, and no problems???
Old May 18, 2005 | 12:31 PM
mofuckinarnell's Avatar
Default Re: can 16 x 8's fit onb a civic??? (JDMJNKY)
i think you can... prolly +35 offset would be the craziest you can go.
Old May 19, 2005 | 05:39 PM
jg's Avatar
jg
Default Re: can 16 x 8's fit onb a civic??? (itsarnellagain)
A 35mm offset on and 8" wide wheel will stick a long way out on a 4th, 5th or 6th gen. civic. I'll be attempting to squeeze a set of 16x8 50mm offset rx7 wheels on my '94 hatch(will be 5 lug) with a 7mm spacer(effectively a 43 offset). We'll see. Regardless, you'll be rolling some flanges all the way around depending on the tire.
Old May 19, 2005 | 09:11 PM
JDMJNKY's Avatar
Default Re: can 16 x 8's fit onb a civic??? (jg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jg &raquo;</TD></TR><TR><TD CLASS="quote">A 35mm offset on and 8" wide wheel will stick a long way out on a 4th, 5th or 6th gen. civic. I'll be attempting to squeeze a set of 16x8 50mm offset rx7 wheels on my '94 hatch(will be 5 lug) with a 7mm spacer(effectively a 43 offset). We'll see. Regardless, you'll be rolling some flanges all the way around depending on the tire.</TD></TR></TABLE>
i don't know much about spacers & flanges can you break it down & post some pics of your setup!????
Old May 20, 2005 | 03:58 AM
jg's Avatar
jg
1- flanges, meaning the 1/2-3/4 inch turned in area on the fender and 1/4 panel sheetmetal in/around the wheel openings.
2- By stating "I'll be attempting..." usually means the task has not been accomplished. Consequenly, there are no photos yet.
3- spacers mount between the wheel and the brake rotor or wheel hub. They move the wheel outward from the centerline of the car effectively reducing offset in the wheel.
I'm not sure how to be much clearer.
Old May 20, 2005 | 10:56 PM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jg &raquo;</TD></TR><TR><TD CLASS="quote">1- flanges, meaning the 1/2-3/4 inch turned in area on the fender and 1/4 panel sheetmetal in/around the wheel openings.
I'm not sure how to be much clearer.</TD></TR></TABLE>
Old May 21, 2005 | 08:32 PM
WaltersCivic17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">
quebecBB6
May 18, 2008 04:54 AM
zirac50
May 14, 2008 03:13 PM
j.dizzle
Apr 10, 2007 01:33 PM
honda_andy
Jun 26, 2006 05:22 AM
Lo-Buck EF
Oct 3, 2003 05:09 PM
