H22A missing
Old May 16, 2005 | 12:40 PM
acclude435's Avatar
Default H22A missing
Any help would be appreciated.
I have an H22A swaped in my CB7 did it last year and everything went fine untilll now. It seems that once the engine is heated up (the fans go on) that it misses during acceleration. I will put it in gear start to go and it will sputter untill I let go of the gas a bit and bring it back up to speed. It will do it in every gear when a slightly harder acceleration is used.
There is no CEL (the light is not burnt)
Fuel quality is good
Ignition timing is good
Also, I am am running Bosch platinum2 plugs, could that be the problem (I was told it might)
Help please
Old May 17, 2005 | 04:59 AM
machine4321's Avatar
first off ditch the bosc plugs..there not the happies in honda motors ...not saying they dont work but i have had no luck with them
it soundle like our dizzy may be on its way out .
does it stutter only when at part trottle while crusing ...and does it clear up if you step on the pedal ??
of course you should do wires and cap and rotor while your at it
Old May 18, 2005 | 02:21 PM
acclude435's Avatar
Default Re: (machine4321)
The problem was actually an overexited knock sensor. I will be getting my ECU remapped to get ridd of that pesky KS for ever. Thanks anyways.
Old May 18, 2005 | 04:58 PM
you sure about that one ...KS should not cause any misses at all ...when mine was still on it was sluggish but not ,issing in the low end ...
H22tuner415
Nov 20, 2008 04:16 PM
Max_GI
Feb 10, 2008 09:15 PM
stunnincivic37
Feb 3, 2007 03:44 PM
ty_racer
Apr 1, 2004 10:45 AM
