Noise in AM Radio
My 97 accord LX has an Am radio you cannot listen to with the engine running. If you shut the engine down the noise goes away. If you are close to a station you can get it to work. I noticed there is a TSB 98-058 on this item. Any ideas what I need to replace add or fix?
There is a in-line filter that you can hook into your setup called a "ground loop isolater". You can purchase it at an automotive electronics store, and if I am not mistaken, Radioshack has them as well.
Modified by jmouchett at 12:50 AM 5/17/2005
Roostalee
Jul 29, 2007 06:33 PM
juangotti
Oct 2, 2003 08:35 PM
