Offset question
Old Feb 5, 2002 | 07:37 AM
KuG's Avatar
KuG
Default Offset question
I'm planning to purchase SSR competition in a little while.
Will I have any rubbing issue with below set up ?
CAR : 00 SI
Comtech Springs with Bilsteins (middle purch)
(lowered about 1.5inches all around)
WHEELS : SSR Competition
16 x 6 +42mm offset
205/45/16 (Kumho ?)
Do I need more of an offset (44-45mm) to avoid any rubbing?
If you have similar set up, please kindly advise.
Thank you
Old Feb 5, 2002 | 08:22 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Offset question (KuG)
No, it should be ok. Your 16X6 is 1" narrower than most at 16X7. It should actually be better than most guys that roll on 16X7s. I don't think you will have any problems.
To give you some idea in comparison, I roll on 15X6.5 on 40mm on 97 Civic, with 1.75F/1.5R drop. It works 95% of the time when I had 195/55/15.
Old Feb 5, 2002 | 08:28 AM
KuG's Avatar
KuG
Default Re: Offset question (GoLowDrew)
Woops. Made a mistake on the size...
It should be 16 x 7
16 x 7 +42mm offset
205/45/16 (Kumho ?)
Old Feb 5, 2002 | 10:07 AM
GoLowDrew's Avatar
Old Member
25 Year Member
It should be ok too. 1.5 drop is not too extreme. I think most guys with 16X7 go with 42mm.
Old Feb 6, 2002 | 06:41 AM
deepnite's Avatar
rota s know hondas..their 16 inchers are all 40 s
Old Feb 6, 2002 | 07:12 AM
JeffS's Avatar
Your biggest concern should be rubbing on the control arms, not on the fender. With 205 tires you should have no problem. Since SSR only makes one offset that's close to right you don't have an option anyway.
If you're worried about it, the 6.5" width will work fine with 205 tires.
raverx3m
Nov 26, 2010 01:34 PM
calde-da9
Sep 6, 2007 09:26 PM
elitesi8
Oct 13, 2006 11:52 AM
highmilehatch
May 7, 2003 08:22 AM
MRDC2
Feb 21, 2003 05:33 PM
