Civic radiator ????????????
I have a 96 civic coupe ex with a b16a swap in teh car and I used the stock sohc radiator and It is working fine but I just cracked the radiator I have a 94 civic cx radiator at home will that radiator fit my 96 civic coupe that is the ? I need to know if that will fit or should I order a new one. Thanx for any Answers from the H-T GODS hahahah thanx for the help guys
isnt the cx radiator a piece?? i remember when i had my cx radiator in the car when i first swapped the motor even just to a single cam vtec that **** always overheated. i would just go find an acura honda junkyard and buy a 2 row for around 70-80 bucks that should be in good condition still
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">isnt the cx radiator a piece?? i remember when i had my cx radiator in the car when i first swapped the motor even just to a single cam vtec that **** always overheated. i would just go find an acura honda junkyard and buy a 2 row for around 70-80 bucks that should be in good condition still</TD></TR></TABLE> well the 96 ex radiator is like the same thing and the car never over heats ever but I really don't beet on the car at so i never give it the chance to let it over heat
I just need a quick fix thats all I don't need anything better or anything And I have the radiator at home I just want to know will it work if not I don't want to look for it in my garage just to find out it won't work
aright yes it should fit fine. my friends got a 96 hatch with a 93 civic 4 door 2 row and he used his 96 fan it worked fine. you can usually mix match parts from any honda to any honda
Whoops I read it wrong. I ran my B16 with my stock VX radiator for a while (approx 3 months?) Now I have one off a 99 Si. It should fit right including the fan, the only problem you will run into is the radiator hose size. You might have to buy new ones, shove it on, or clamp it tight as all hell.
racekar
Aug 17, 2004 11:46 AM
