what are all these ports for on the AEBS intake manifold?
Old May 16, 2005 | 08:28 AM
Black R's Avatar
25 Year Member
Default what are all these ports for on the AEBS intake manifold?
I'm about to help my buddy put this on his EM1, and my itr IM doesn't seem to have this many ports last I checked.....
Old May 16, 2005 | 08:43 AM
CRVTEC0WNZJ00's Avatar
Default Re: what are all these ports for on the AEBS intake manifold? (Black R)
I'm interested as well because I'm using this manifold for my swap. One is for the PCV, MAP, Brake Booster, Charcoal Can, FPR...thats about all I can think of right now
Old May 16, 2005 | 09:07 AM
hayabusa160's Avatar
i dont think you use all of them.
Old May 16, 2005 | 10:04 AM
Autoworks's Avatar
Default Re: what are all these ports for on the AEBS intake manifold? (hayabusa160)
You won't use them all. You can just loop the unused ones. On my B16 I had 3 left over. Closed one off, and looped the other 2 together. You could always use them for vacuums for BOV's or whatever.
Old May 16, 2005 | 11:25 AM
JerseySiPOS's Avatar
Default Re: what are all these ports for on the AEBS intake manifold? (Autoworks)
like someone else said, the biggest one is for the brake booster.
the other 2 big ports are for the PCV and EVAP can. If it's switched to an OBD1 ecu, put a rubber plug on one of the big ports and on the evap can, or just take it out.
The little ports are for Cruise control, FPR, and close the extra one.
I used an AEBS not even made for the EM1. So there were only 2 big ports and 2 little ports.
Old May 16, 2005 | 11:43 AM
Used2beAb16's Avatar
Default Re: what are all these ports for on the AEBS intake manifold? (JerseySiPOS)
Just block them off, and dont forget about the little port on the front right side right by where the fuel rail goes. If you have an EM-1 you can see that stock mani has the cast for it but its sealed off, well the one ont he AEBS is open and you will have problems if u dont close it.
Old May 16, 2005 | 12:12 PM
urmomluvsme's Avatar
they would be nice if you were going turbo and needed the extra vacuum ports, that's why they are there
pelayo114
Dec 14, 2013 09:32 AM
Terrabomb
Jul 23, 2005 01:53 PM
acurar0ss
Apr 20, 2005 10:45 AM
Just Checking In
May 9, 2003 06:08 PM
