Friends accord with H22 having problems
Old May 16, 2005 | 07:36 AM
VisPreludeVtec's Avatar
Default Friends accord with H22 having problems
My buddy has a 99 H22A4 in his 95 accord, converted to OBD1 with a hasport wire harness. When the harness got here, they had 3 days to get the motor in because he was going to a show and the wiring wasnt all correct so one friend rewired the incorrect portions. He has just got a GSR ECU to run it with vtec(he had been using his accord ECU) and when the GSR ecu is plugged in the car bogs down when sitting at idle, and even stalls out. since this was giving us problems we took my h22 ecu out and put it in his car and it run a little better then the GSR but it still bogs down and stalls out. The GSR ecu worked fine in my car. We plug the Accord ecu back in and it runs fine and is drivable. Any idea what could be causing this problem? Thanks
Old May 16, 2005 | 07:44 AM
h22 booster's Avatar
Default Re: Friends accord with H22 having problems (VisPreludeVtec)
so originally and now, the accord ecu works with his motor?
Old May 16, 2005 | 07:57 AM
Monkey Fing a Coconut's Avatar
Default Re: Friends accord with H22 having problems (h22 booster)
first unless the p72 (gsr ecu) is chipped for a prelude, dont run it, second, since the accord ecu is running fine and the p13 is not, im guessing you have not switched the wires for a6 and a11, a6 should be for o2 sensor (cause of bogging) and a11 is for egr, check that out...its prolly whats wrong
Old May 16, 2005 | 08:20 AM
Default Re: Friends accord with H22 having problems (twistedbydezign)
yes accord ECU is working then and now. Thanks we will check that out, anybody else have ideas?
Edit: just spoke to the owner of the car, they switched those wires last night so in saying that should the H22 ecu work fine in it now? Also I thought the p72 was interchangable with the p13. We put the p72 in my car to test and it worked fine so it should still work in his without shutting off? thanks
Modified by VisPreludeVtec at 12:31 PM 5/16/2005
Modified by VisPreludeVtec at 5:42 PM 5/16/2005
Old May 16, 2005 | 08:40 AM
p72 will plug in and run, however its made to run a 1.8l engine, so you will be running way lean and can damage the motor, if youre using it to just start the engine and test at idle its fine, but dont drive around or go anywhere near vtec with a stock p72, and if they switched the pins last night you should be good to go with the p13
Old May 16, 2005 | 08:55 AM
they switched it but it still bogs and stalls out. it will Idle ok for like 1 or 2 minutes after you rev it but then it bogs down and stalls. no CEL either
Old May 16, 2005 | 10:09 AM
check for loose vacuum lines, or maybe map sensor wiring
Old May 16, 2005 | 11:00 AM
alright, ill get him to look into that thanks alot
Old May 16, 2005 | 11:24 AM
fastludeh22's Avatar
how did you convert to obd1? change distributors and the whole 9?
ALSO what injectors are you using, a4 will not work w/p13...way to small injector.
Old May 16, 2005 | 11:30 AM
Default Re: Friends accord with H22 having problems (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">how did you convert to obd1? change distributors and the whole 9?
ALSO what injectors are you using, a4 will not work w/p13...way to small injector.</TD></TR></TABLE>
yes everything was converted, well that explains why the h22 ecu worked better then the GSR ecu, the h22 only bogged some but never stalled, the GSR ecu stalls out time after time
Old May 16, 2005 | 01:41 PM
bump for any more ideas before I leave work. Any idea why the p13 bogs some when at idle but never stalls
Old May 16, 2005 | 01:47 PM
93HONDAACCLUDE's Avatar
any pics of this wiring your talking about.
i might be having same problems
Old May 16, 2005 | 03:11 PM
Default Re: (93HONDAACCLUDE)
no pics ill see if i can get some
TrademarkAccord
May 6, 2013 04:31 AM
jdmkidd23
Mar 3, 2009 09:30 AM
Billy_Bob
Dec 22, 2007 05:01 PM
3litre190
Jul 24, 2007 02:49 PM
GqchYnAbOy
Dec 8, 2004 09:03 PM
