Sway bar question. Searched.
Old May 15, 2005 | 11:54 PM
JTCdudeman's Avatar
Master H Technician
Default Sway bar question. Searched.
This is a very simple question, but I couldnt find any relevant info anywhere. I believe my rear sway bar is bent. Ive done everything short of taking it off.. Its stock.
My car sits off in the back. I have coilovers and I have to raise one significantly higher than the other in order to get an even ride height. This is a semi-recent issue. When I jack the car up one wheel hangs much lower than the other one. I believe this is due to the sway bar being bent right there around the end link causing one side of the bar to sit much higher than the other.
I am looking for an expert opinion if possible. Suspension info isnt nessecary. I put all the relevant info honestly. But, just for the people who really dont understand sway bars... I am using aftermarket shocks and coil-overs.
I will be taking the car in for an alignment very soon, I guess Ill find out then unless someone can confirm my issue beforehand and save me $$ on 2 alignments. Which leads me to anyone know of any sway bar deals going on right now?
Old May 16, 2005 | 05:52 AM
Honda318dx's Avatar
Default Re: Sway bar question. Searched. (JTCdudeman)
Just disconect one end of the swaybar and see if it fixes your problem, if not, then its not your swaybar.. I have never heard of a bent swaybar so this issue is slightly odd..
Old May 16, 2005 | 09:40 AM
syntax.'s Avatar
Default Re: Sway bar question. Searched. (Honda318dx)
Never heard of a bent swaybar either, but when i bought my 92 lude si i found the rear swaybar was snapped right in two. the welded tubular bars seem to be pretty weak, so i believe bending one could be possible.
RdmptionCivic
Suspension & Brakes
29
Jul 23, 2011 12:33 PM
NTGR8D
Nov 30, 2003 11:50 AM
speedevo
May 18, 2003 11:46 PM
Gump
Oct 24, 2001 02:51 PM
