help needed
Old May 15, 2005 | 11:18 PM
tgjpwa's Avatar
Default help needed
how much work/what is needed to do the swap from d16a6 dpfi to mpfi i found about the wireing and i know i would need new intake manifold and fuel rail/injectors and head so which head can i use on that car...and can i make it into dohc???
Old May 16, 2005 | 06:56 AM
CloudPump's Avatar
Default Re: help needed (tgjpwa)
Well for starters you don't have a D16a6 if it is DPFI, you have a d15b2. There are no DPFI D16a6's. How much work is it? well it's a bit of wiring, I've done the conversion myself and it's about a days work for someone with some tool skills. You will also need an A6 distributor, your current distributor will not work, you're also going to need an Injector Resistor box from an OBD0 MPFI car as well. What head can you use on the car? You can use your current B2 head, an A6 head which is identical except for the cam or you can put on a SOHC VTEC head from a 92-95 civic Si (D16Z6) or from a 96-00 EX (Si for Canada) (D16Y8).
Finally, no you can not make it DOHC.
PS. If you plan on doing a head swap to one of the SOHC VTEC heads at the same time, some small additional work will be needed.
-Geoff
Old May 16, 2005 | 10:16 AM
tgjpwa's Avatar
Default Re: help needed (CloudPump)
i can take a picture of it if u want...the engine code is d16a6 but it def is converted to dpfi...so its just some wireing and thats about it tho...cause the motor is outa a crx si but its in a civic dx so i guess the kid i got it from didnt know how to switch the wireing so i guess thats why its like that
Old May 16, 2005 | 11:18 AM
Bserieskllr's Avatar
well you keep the a6 head just use the a6 intake manifold/rail/injectors, there are plenty of sites that show how to wire it and no you cant put a dohc head on it.
Old May 16, 2005 | 12:55 PM
vegaskurt's Avatar
Default Re: (Bserieskllr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr &raquo;</TD></TR><TR><TD CLASS="quote">well you keep the a6 head just use the a6 intake manifold/rail/injectors, there are plenty of sites that show how to wire it and no you cant put a dohc head on it.</TD></TR></TABLE>
I think what he is saying, is that someone swapped the b2 out of his car and put the a6 in with the b2's intake. So he has a dpfi a6. If you want to make it mpfi go look at the fourthgen write up at http://www.4gcivic.net
Old May 16, 2005 | 02:51 PM
yea i know what he was saying i was telling him to keep his a6 head cause i thought he was saying that he had to cahnge the head for the mpfi swap but i guess a i read wrong.
Old May 16, 2005 | 11:23 PM
tgjpwa's Avatar
yea but i dont have an a6 head...when the kid did the swap he didnt want to change the wireing of the car...its a 91 civic hb with an 89 crx si block and the hb head distributor and intake manifold....
Old May 16, 2005 | 11:39 PM
NikoZai's Avatar
Default Re: (tgjpwa)
Checkout Rywire.com.
I don't think i can determine what your setup is by what you've said, nothing makes sense LOL
Standard DPFI to MPFI conversion is $160. You send your harness, we convert it. Wiring is Done..
Thats the easy and reliable way with tech support ..
Or you can do it yourself.
And welcome to Honda Tech CloudPump cool to see you here
Old May 17, 2005 | 07:37 AM
vegaskurt's Avatar
The heads on the dx ans si are the same. The only difference is the cam. Take some pics and post them up.
Old May 30, 2005 | 11:54 AM
tgjpwa's Avatar
yea but will the dx dizzy work on the si motor???
Old May 30, 2005 | 01:05 PM
Kwicko's Avatar
Not with the MPFI swap, it won't. MPFI and DPFI use different distributors.
For as complete a list as I could find on what all you need, look on http://www.effinmotorworks.com. Go to their technical section and look up the DPFI/MPFI swap page. It should included every single thing you'll need.
Mike
Screaming
Feb 18, 2006 04:47 AM
Layziebtnh055
Apr 29, 2004 01:44 PM
hondacivic4g
Aug 8, 2003 01:27 AM
uneek4dr
10
Dec 19, 2002 12:08 PM
civicextpa
May 20, 2002 12:49 PM
