Remove stock intake and box, any gains?
Old May 15, 2005 | 08:19 PM
ghost SHell's Avatar
Default Remove stock intake and box, any gains?
If I were to remove the stock intake box and pipe so that it was just an open throttle body, would there be any problems? Would there be any hp gains?
Old May 15, 2005 | 08:35 PM
Dulluthkid_19's Avatar
Default Re: Remove stock intake and box, any gains? (ghost SHell)
Ud do this with no air filter on the throttle body? If so, that is not smart at all...
NA's need a velocity stack, such as the intake elbow to smooth out incomming airflow into the engine, it would probably restrict air intake into the engine if you removed the elbow.
Dont get ghetto dude, keep the 5th gen clean
Old May 15, 2005 | 08:43 PM
jdmlude_dude's Avatar
Default Re: Remove stock intake and box, any gains? (Dulluthkid_19)
i know in the 4th gen you cam remove the piping crap that is outside the engine bay and sort of turn your intake into a cold air. I did that for time being until i can buy another intake. I think it makes a little different. The stock piping under the box just sucks hot air in from the engine bay, and twists and turns the air all around. So there has to some gains, but how much in that case i do not know. with the open throttle body...you can really mess some stuff up, especially if it was to suck something in.
Old May 16, 2005 | 05:59 AM
Default Re: Remove stock intake and box, any gains? (jdmlude_dude)
In this case, how does Individual Throttle Bodies work?
Old May 16, 2005 | 06:32 AM
my guess would be that with ITB's it allows each cylinder to EVENLY suck air in. With just an open throttle body i could try to suck so much air into the 4th cylinder that it may starve cylinder one for air. Now i cant say that for sure but it does seem reasonable. The only thing that makes ITB's what they are is the fact that it can get quick, even distibution of air through the cylinders and can also allow a TON of air to be sucked in..but evenly. That would be my theory!
Old May 16, 2005 | 12:12 PM
equinox's Avatar
never really understood ITB's. How do they filter air?
Old May 16, 2005 | 12:28 PM
92hondalude's Avatar
Default Re: Remove stock intake and box, any gains? (lude_roller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_roller &raquo;</TD></TR><TR><TD CLASS="quote">never really understood ITB's. How do they filter air?</TD></TR></TABLE>
i dont think they do
I wouldent put that on my car.
plus you spend so much on them for not the much of a gian.
I like turbo better
Old May 16, 2005 | 12:47 PM
flip1199's Avatar
they dont. most use itb for race applications. but u can get little filters for them if your really that concerned about getting stuff in your engine. I've run my old stock si numerous times without a filter and never ran into any problems. although this was only at the track.
boooom
Sep 26, 2016 04:52 AM
p1driftfiend
18
Sep 3, 2004 06:04 PM
otokoyama
Apr 6, 2004 07:20 PM
batman21
Jan 22, 2004 08:57 PM
LFA Squad :: iTO
Dec 8, 2003 03:40 PM
