Solid Motor Mount Inserts off Summit Racing... any good?
Old May 15, 2005 | 07:33 PM
Dropped90Integra's Avatar
Default Solid Motor Mount Inserts off Summit Racing... any good?
Like title says... the look ok but do they actually do a decent enough job to get rid of the thump of the motor when hard shifting? Anyone know what motor mounts these inserts will cover also?
http://store.summitracing.com/...h.asp
Old May 15, 2005 | 07:35 PM
Default Re: Solid Motor Mount Inserts off Summit Racing... any good? (Dropped90Integra)
To add another question, whats the difference between the one above and this one??? http://store.summitracing.com/...h.asp
Thanks
Old May 15, 2005 | 07:38 PM
Lol, i'm having all kinds of trouble tonight.... ok, if anyone will actually do this, the inserts i'm talking about on summitracing.com are PTP-8-1908 & ENS-16-1109G Hopefully that'll work and someone knows
Old May 16, 2005 | 01:46 PM
Anyone?
Old May 17, 2005 | 10:03 AM
AIminiS10's Avatar
I put in the energy suspension motor mount in my teg and they made a world of a difference. I have 3rd gen teg and they inserts go in the tourque mounts (the one on the bottom of the tranny and the one that is part of the ac bracket) and the rear motor mount. I haven't put the rear inserts in because they are a bitch to get in, but just the other two replaced made an awesome difference. There isn't any delay of when I hit the gas like it was before. You do feel more vibrations within the car though, but I can live with that!!
Old May 17, 2005 | 06:33 PM
Default Re: Solid Motor Mount Inserts off Summit Racing... any good? (AIminiS10)
Yea thats what I'm about to order are the ES Inserts.. but I was hoping someone with a 2G Teg knows anything, the DA's only have 4 mounts, 1 front, 1 rear, and 1 on each side and in the ES Kit, one insert isn't given, I'm thinking its the tranny mount but that one I can just fill in with something to make it solid i suppose.
Old May 17, 2005 | 07:37 PM
CNSK's Avatar
i have prothane motor inserts and the inside of my car vibrates like crazy but definetly lost the wheel hopping....
Old May 18, 2005 | 06:29 PM
Default Re: Solid Motor Mount Inserts off Summit Racing... any good? (CNSK)
I hope the ES Inserts gets rid of my wheel hop, i could care less about vibrations, my exhaust already does that enough, lol
Old May 18, 2005 | 09:25 PM
korean_teg's Avatar
If it's a daily driver the vibration will wear on you shortly. I just used ITR mounts.
Old May 19, 2005 | 01:12 AM
eMpAtHy's Avatar
Default Re: Solid Motor Mount Inserts off Summit Racing... any good? (korean_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korean_teg &raquo;</TD></TR><TR><TD CLASS="quote">If it's a daily driver the vibration will wear on you shortly. I just used ITR mounts. </TD></TR></TABLE>
i agree. vibrations are going to be friggin crazy. ur going to hate it.
Old May 19, 2005 | 02:38 AM
Takumi Fujiwara's Avatar
Default Re: Solid Motor Mount Inserts off Summit Racing... any good? (eMpAtHy)
Having all 3 inserts installed (2 lower & rear) does not create much vibration at all. If this bothers you, then live with wheel hop. I'm running jimfabs... the inserts didn't have enough vibration for me...
Old May 19, 2005 | 07:18 AM
typerhedlights's Avatar
honestly with the ES inserts it doesnt vibrate at all. and if you idling where you should be (750-900) then it basically cancels it out and its smooth. im idling a little low right now and it vibrates but not enough to bug me. and im pretty nitpicky when i hear vibrations and random stupid sounds. go for it i say! its a must if you have aftermarket parts
Old May 19, 2005 | 06:08 PM
Default Re: (typerhedlights)
Thanks, I'm gonna do it.... The ES inserts only cover 3 mounts so whatever mount it doesn't cover I'm just gonna fill it with something to make it solid.
steveharrmr23
May 1, 2008 08:34 AM
allanonjj
23
Jul 2, 2005 09:24 PM
JUN JDM
Jul 13, 2003 08:11 PM
p10hlm
Nov 30, 2002 02:05 PM
