Gearing not working once turbo
Old May 15, 2005 | 06:16 PM
abmerop18's Avatar
Default Gearing not working once turbo
Ok I have a 2002 civic lx that I just turbo'd today and I am now havign some trouble with my gearing on it. I have an ACT clutch installed and I know that it is not bad. The problem is I cannot even get the car to go into any gear once I finished the turbo install. I press the clutch down all the way and it will not go into any gear at all, it just grinds when i try to put it in gear. I can put it in gear with the car off though. I did try putting it in 1st gear with the cra off then turning the car on with my fott completely ont he clutch though. It was weird, the car started going forward like I was giving ti gas and my foot was still completely on the clutch. Anyone have any idea wtf is the problem?
Old May 15, 2005 | 06:19 PM
abmerop18's Avatar
Default Re: Gearing not working once turbo (abmerop18)
also, i never even drove the car once it was turbo. just revved it a couple times to make sure everything was working fine.
Old May 15, 2005 | 06:27 PM
tfnaaf's Avatar
When you press the clutch pedal down is it moving the fork in the tranny? Did the install block or cause the slave cyl to bind?
Old May 15, 2005 | 06:31 PM
Soccerking3000's Avatar
Default Re: (tfnaaf)
i helped with the install and we didnt touch anything with the tranny, the only issue we had was with the hard line on the front of the tranny was in the way of the compressor housing , but after all said and done it didnt cause a problem, i dont beleive its dented or anything either...
Old May 15, 2005 | 06:32 PM
abmerop18's Avatar
Default Re: (Soccerking3000)
i think that line right under my intake side of the turbo is the slave sylinder. i am goign to check that real quick
Old May 15, 2005 | 06:37 PM
95turboex's Avatar
as long as all of your lines are good it sounds like a fluid problem. Does the pedal feel any different? Check to make sure your fluid level in the master cylinder is right, and you may want to bleed the clutch line just to make sure thats not the problem.
Old May 15, 2005 | 06:56 PM
abmerop18's Avatar
Default Re: (95turboex)
is there anby rason the slave cylinder would just go when i install the turbo? what can i do to check if it is that?
Old May 15, 2005 | 07:17 PM
95turboex's Avatar
Default Re: (abmerop18)
if the slave cylinder is gone you will notice some brake fluid leaking out of the side with the boot.
Old May 15, 2005 | 08:30 PM
tfnaaf's Avatar
Have a buddy push on the clutch and watch the slave to see if its fully applying the clutch.
Old May 16, 2005 | 05:08 AM
abmerop18's Avatar
ug. this cant be good. i tried pumping the clutch pedal to build pressure back in the clutch lines and did this a couple times before something not so good happened. as i was pumping the clutch, i heard a popping noise and then the clutch pedal stuck to the ground. anyone know wtf this could be? i think i am just goign to have to take my car to the local clutch and transmission place for them to figure out
Old May 16, 2005 | 06:07 AM
abmerop18's Avatar
as i take a look in the engine bay, the bracket for the slave cyliner is completely broken in half, so i think that may be the problem i am having. anyone ahve any input on this?
Old May 16, 2005 | 06:57 AM
sadangryboi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abmerop18 &raquo;</TD></TR><TR><TD CLASS="quote">as i take a look in the engine bay, the bracket for the slave cyliner is completely broken in half, so i think that may be the problem i am having. anyone ahve any input on this?</TD></TR></TABLE>
you just answered your own question. that bracket holds your slave stationary...so if its broken, therwes no way your slave will be able to push pressure onto the fork to engage/dissengage the clutch.
You just found your own problem and fix
Old May 16, 2005 | 08:37 AM
abmerop18's Avatar
Default Re: (sadangryboi)
would that be the same reason why my clutch pedal popped and is now dead?
Old May 16, 2005 | 08:54 AM
yeap
Old May 16, 2005 | 09:26 AM
abmerop18's Avatar
good deal hopefully this should be an easy fix then.
Old May 16, 2005 | 10:33 AM
Hyaboosta's Avatar
same thing happened to me on my 02 civic. the ACT clutch was a bit harder at first and the slave might not have been lined up right and the extra force broke it off. Just replace the slave and bleed the system and your good to go.
Kidnkorner
Honda Civic (2006 - 2015)
21
Aug 21, 2008 09:52 AM
Kicker773
Dec 21, 2003 09:47 PM
HmgLauj69
Apr 23, 2003 08:10 PM
MCP486
Jan 13, 2003 03:43 PM
NickGSR
Sep 15, 2002 05:26 PM
