Done with h22a swap and manual conversion
Old May 15, 2005 | 04:34 PM
redlude04's Avatar
Default Done with h22a swap and manual conversion
If you have seen my other thread i have pictures of the swap and the process all that stuff,but now she is DONE.long trip to get here lots of money for a 16 year old but wouldnt trade it for the world love the car ive been in it all day.
List of mods
1992 prelude si(h22a)
manual conversion
LSD tranny
world sport 2 exhaust
dc headers
OBX cams (stage 1)
short ram intake
kyb shocks
pollyurithane bushings
new shocks and all pollyuithane bushings
[IMG][/IMG]
me next to the car
[IMG][/IMG]
[IMG][/IMG]
first time driving it
[IMG][/IMG]
thanks for looking
Old May 15, 2005 | 04:39 PM
optikal_blitz's Avatar
haha you're so happy!
congrats on the swap and all.
Old May 15, 2005 | 05:04 PM
AndyD's Avatar
Default Re: (.:optikal_blitz:.)
AWESOME, man. I know the feeling.
Old May 15, 2005 | 05:37 PM
jnet's Avatar
Default Re: (AndyD)
now all you need is a big turbo!
Old May 15, 2005 | 05:44 PM
spoolinlude's Avatar
I live under a rock
Default Re: (jnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnet &raquo;</TD></TR><TR><TD CLASS="quote">now all you need is a big turbo!</TD></TR></TABLE>
or not......
Enjoy it...... wish i had something like that when i was 16
Old May 15, 2005 | 05:47 PM
steveobb4's Avatar
Default Re: (jnet)
Hey Redlude04, where did you buy the clutch hard line that goes from your clutch master cylinder to the clutch dampner assembly mounted by the tranny? Majestic Honda? Or did you bend one yourself. Also did you wire up your reverse lights and clutch switch for the starter? Im doing this conversion in 1 month.
Steve
h22a93lx's Avatar
Default Re: (spoolinlude)
nice i was the same way when my swap was done in the accord have fun
Old May 15, 2005 | 05:55 PM
mgags7's Avatar
being that you are 16, and probably dont have enough money to do constant engine maintenence and rebuilds...
KEEP IT NA!!!
p.s na is best anyways, duh
steveobb4,
the best place to get a clutch line is a junkyard, but you could bend one yourself......
also, the soft line that connects from the end of the hard line on the chassis to the tranny is really expensive, and you cant get one made at a brake shop, because nobody has the banjo bolts with the bend like honda puts in it, and if you get a straight one, it will leak, like mine....it hits this one bracket even after being bent out of the way....
i think something good to consider would be to just get a woven stainless line to go from the master cyl straight to the slave....
1)Way easier to find leaks, only two possible leak points instead of 6.....
2)Way easier to bleed
3)No crappy dampener, those things accumulate junk inside and ruin brake fluid...
im gonna start looking for a line like that....ill put up a post when i find one....i think it would be a good "mod" even for people with oem manuals....
on the car, have fun, that is the best feeling to be done....
Old May 15, 2005 | 06:02 PM
2point2's Avatar
i would like a link to your other thread? i'm converting an accord from auto to manual in the near future.. i cant find it!
Old May 15, 2005 | 06:09 PM
steveobb4's Avatar
Default Re: (mgags7)
mgags, i have the whole clutch dampner assembly and the soft rubber hose and banjo bolt with all the crush washers from my jdm clip, I can even use the jdm rhd clutch pedal assembly but it only has the clutch switch to deactivate cruise control and no clutch starter bypass switch(i found that odd) . All i need is the line from the mast,cyl to dampner, I saw in the accord forum someone used a stainless line so i might consider it.Thanks
Redlude04,
Did you use any spacers between the nuts that thread onto the clutch master cylinder studs? My jdm front clip which is a BB1 5spd has about a 12mm spacer welded to the fire wall. Thanks
Old May 15, 2005 | 06:12 PM
Sam1am26's Avatar
Awesome man... Glad to see more young people having the knowledge to do swaps and properly modify their engines... I'm sure you will have plenty of fun with the h22... I was still 17 when I started building my h23 vtec and I'm only 19 now and I've <U>finally</U> boosted my second hybrid motor... It feels good...
Old May 15, 2005 | 06:28 PM
jnet's Avatar
Default Re: (Sam1am26)
im 17 and i love my boosted prelude, it's also very reliable and i haven't had to do tons of maintenance like everyone thinks they do with a turbo. really all i've had to do is change oil. if things are tuned properly and the setup is reasonable (meaning you're not putting out high hp #'s..400+) a turbo honda is just as reliable. there are more parts to worry about and more things that can go wrong, but it will last for quite awhile. also, my MPG has remained the same, about 28mpg highway and 24mpg city, boosting at 5psi daily around 230whp.
Old May 15, 2005 | 06:57 PM
boostedlude97's Avatar
Default Re: Done with h22a swap and manual conversion (redlude04)
Congrats!!!!!!! Theres no better feeling than acomplishing somthing that u wanted to do, by urself!
Old May 15, 2005 | 08:04 PM
Monkeyballs's Avatar
Default Re: Done with h22a swap and manual conversion (boostedlude97)
yeah, i know how u feel...
it was always one thing after another with my jdm h22 swap.
even when it was all done, it was still a week or so till it was right.
but i didnt do it myself, my best friend did it for me. that ****** really hooked me up.
Old May 16, 2005 | 10:51 AM
redlude04's Avatar
Default Re: Done with h22a swap and manual conversion (twopoint5lude)
I bent the line myself wasnt that hard i did have help from my dad but it can be done without to many headaches. It does feel great to have the swap done,By the way i suggest world sport exhaust to anyone the best exhaust in my opinion quiet as anything.
I am going to keep it N/A for now i dont have the money gor turbo but i have a set of cams and today or tomorrow im going to get cam gears injecors and fuel rail.im trying to keep everthing together in sence of buying it because i know if u have a throttle body like without injectors you will never have the max performance, but im learning alot,Im still new but im very excited and this is something that i love to do.
Old May 16, 2005 | 02:06 PM
steveobb4's Avatar
Redlude04,
Old May 17, 2005 | 03:03 AM
redlude04's Avatar
Default Re: Done with h22a swap and manual conversion (steveobb4)
the clutch master cylnder will bolt right up to your fire wall,we did not use the spacers just bolt it up and it will be fine.
Old May 17, 2005 | 04:13 AM
Lewdin' Incognito's Avatar
Looks good man .
Now about that antenna.....
Old May 17, 2005 | 09:11 AM
97lude's Avatar
Old May 17, 2005 | 09:43 AM
iwubmybb4's Avatar
do you have the writeup for this swap? if so will you plz post it, thank you.
Old May 17, 2005 | 03:51 PM
steveobb4's Avatar
Redlude, did you just leave the automatic gear position switch in park? Or did you wire up a clutch bypass switch?
Old May 18, 2005 | 11:19 AM
redlude04's Avatar
i kept it in park because u will not be able to get your key out if isnt so place it in park and i just stuffed it in the back.i didnt use the clutch bypass.
Old May 18, 2005 | 12:15 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlude04 &raquo;</TD></TR><TR><TD CLASS="quote">I bent the line myself wasnt that hard i did have help from my dad but it can be done without to many headaches. It does feel great to have the swap done,By the way i suggest world sport exhaust to anyone the best exhaust in my opinion quiet as anything.
I am going to keep it N/A for now i dont have the money gor turbo but i have a set of cams and today or tomorrow im going to get cam gears injecors and fuel rail.im trying to keep everthing together in sence of buying it because i know if u have a throttle body like without injectors you will never have the max performance, but im learning alot,Im still new but im very excited and this is something that i love to do. </TD></TR></TABLE>
Injectors and a fuel rail are a waste.
Research before you just start buying stuff. Many waste A LOT of money because they think slapping mods on their car will make it faster.
xx_jumpman
Nov 7, 2017 04:31 AM
gripnslide
Jul 9, 2007 05:44 AM
2point6
Aug 16, 2005 09:35 AM
eg ferio
12
Jul 19, 2003 04:33 PM
93Accord
Feb 25, 2002 06:23 AM
