Rear suspension diagram
search here hondaautomotiveparts.com
however, the part #'s will not be the same, as Honda dealers are not allowed to post part #'s, so they come up with their own to post up on the web. it should give you an estimate.
will you be doing the repairs yourself? or... just looking at what needs to be fixed?
Yes, I will be fixing it... I need quite a few parts. =| I cracked the rim, broke the axle right off, then some of the "arms" holding the wheel on are severly bent. We have it all taken apart, now I just need to figure out the part names.
only thing I can say to watch out for is odd alignments in the rear once everything is back in order. you *might* need to take it to get the frame adjusted.
I actually have a handful of right rear suspension pieces, but they were leftover from a friend's incident like your own. the arms are quite heavy. I saved them for the bushings actually. and some of them have been used up already.
how is the bumper and panels?
HondaMarketPlace
Jan 10, 2004 05:09 PM
Vracer111
15
Dec 23, 2003 11:49 AM
slowassR
Aug 14, 2002 04:58 PM
2000, acura, civic, diagram, diagrams, fit, honda, names, parts, picurest, rear, s2000, suspencion, suspension, suspensions
