Special Lugs for Volks?
Old Feb 4, 2002 | 11:08 PM
98R-1144's Avatar
Default Special Lugs for Volks?
do the volk te37s need special sized lug nuts? will the stock ones suffice? every pic i've seen of them on a car seems to have different lugs than i do =T
Old Feb 4, 2002 | 11:09 PM
Type Goch's Avatar
New User
Default Re: Special Lugs for Volks? (98R-1144)
probly sporting the volk lugs..
Old Feb 4, 2002 | 11:26 PM
B2FiNiTY's Avatar
I think you can use aftermarket lugs like volks, kyogen(sp), etc.
Old Feb 4, 2002 | 11:48 PM
Tommy_Gunns's Avatar
They require tapered lug nuts. Stock lugs are acorn style...they (the lug nuts) would work but it would not seat properly.
Old Feb 5, 2002 | 04:03 AM
1GreyTeg's Avatar
A nice SEARCH would have found this topic covered before: https://honda-tech.com/zerothread?id=116106
AND:
As quoted from my RAY's service manual: "There are several types of nut shapes including taper, spherical and flat. A 60 degree taper is used for this wheel.
Nut/Bolt(S) of incorrect shape MUST NEVER BE USED as they may result in insufficient tightening and may fall off during driving!"
So go get the right bolts cause it would certainly suck to have one of those wheels fall off during a cruise or at a good pace on thw highway.
Good luck, Be safe, and get the correct LUG's
A.
Old Feb 5, 2002 | 04:30 AM
Dipshit Dan's Avatar
Default Re: Special Lugs for Volks? (1GreyTeg)
Actually all Volks come with the lugs but they are kind of cheap ones. The Ray's ones are optional.
Old Feb 5, 2002 | 02:44 PM
98R-1144's Avatar
i guess i'm steering towards the Kyokugen or Rays Eng. lug nuts to fit on the TE-37s. it says that they come with a special key because the nuts are 7-sided. does that mean that anybody with the Kyokugen or Rays key can take off my lug nuts... or *only* my key will be able to remove *my* lugs?
Old Feb 5, 2002 | 02:54 PM
GiFF's Avatar
i have some experience with both. kyogeken nuts i personally think are not good, the key that they gave you is cheap. i've stripped 3 of there keys. they're ok if you don't let anybody use an impact gun on them. always torque on spec. i've changed to volks lug nuts after stripping so man keys...
Old Feb 5, 2002 | 03:44 PM
Toda Party's Avatar
Default Re: Special Lugs for Volks? (G CHAN)
speaking of which, what about the Spoon/Regamaster's? I saw that Darth Vader used the Ray's lug nuts on his Regamasters...
Old Feb 5, 2002 | 05:51 PM
SIINSI's Avatar
Default Re: Special Lugs for Volks? (Toda Party)
I'm planning on using them on Spoon's, hope they fit
Also, on TE-37's But, I'm sure they'll fit.
Miguel
Old Feb 5, 2002 | 06:02 PM
-Gambit-'s Avatar
i am using kyokugen on mine
Old Feb 5, 2002 | 06:32 PM
sackdz's Avatar
Default Re: Special Lugs for Volks? (ek9hatch)
Does anyone know of a place that has the gunmetal Kyokugens in stock? I'm able to find black but I'd rather have gunmetal, but everyone seems to be out. Then again maybe I shouldn't care since after all, they're just "track" lugs
teamvirus
Jan 26, 2006 04:50 AM
civicrights
Oct 16, 2003 05:48 PM
KF_S2000
Feb 2, 2002 02:51 PM
