obd-0 to obd-1 in ef
Old May 15, 2005 | 12:40 PM
4ghatch's Avatar
Default obd-0 to obd-1 in ef
i have a b16a1 in my 91 dx hatch (v tec is wired and setup for mpfi ) now i want to get all i need to make it run obd-1 i know i need the ecu,dizzy,and the 4-wire 02 sencer but do i need obd-1 injector clips, obd-1 alternator, also id like to use a itr intake manifold ( the an-r intake manifold with itr throttle body w/the map sencer ) will i be able to remove the fire wall map sencer and the whole bracket
please list what i need
Old May 17, 2005 | 03:12 PM
Blown90hatcH's Avatar
Default Re: obd-0 to obd-1 in ef (4ghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ghatch &raquo;</TD></TR><TR><TD CLASS="quote"> i have a b16a1 in my 91 dx hatch (v tec is wired and setup for mpfi ) now i want to get all i need to make it run obd-1 i know i need the ecu,dizzy,and the 4-wire 02 sencer but do i need obd-1 injector clips, obd-1 alternator, also id like to use a itr intake manifold ( the an-r intake manifold with itr throttle body w/the map sencer ) will i be able to remove the fire wall map sencer and the whole bracket
please list what i need </TD></TR></TABLE>
OBD1/2 injector/clips are optional. Remove the resistor box = run the OBD1/2 injectors. Keep the resistor box = run the pre obd injectors. OBD0 alt works fine, keep it. You can use any map sensor you want.
http://www.JKobd.com comes with full detailed instructions and more tech support if needed.
hatcht9x
Jul 29, 2009 11:13 PM
alscrx
Nov 15, 2008 12:17 PM
1sikhatch
Sep 20, 2007 09:48 PM
civicandy
Apr 16, 2007 10:45 AM
