what is this, and do i need it?
Old May 15, 2005 | 11:18 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default what is this, and do i need it?
hey guys, well i hid all my wires recently and my motor is on its last leg so i just pulled it this weekend and trying to clean up the bay again. i have this relay or whatever is mounted next to the headlight, so i took it off and just stuffed it under the headlight to hide it. what im wondering is whats it for and do i need it. thanks
Old May 15, 2005 | 11:33 AM
b16_madman's Avatar
Default Re: what is this, and do i need it? (floss)
i'm sure you need it
Old May 15, 2005 | 11:36 AM
crxtreme89h's Avatar
Follow the wires and see where they go. It may be used to turn off the low beems when your high beems are turned on. Or maybe, to have the bumper lights flash, then your corner lights flash, then your bumper lights flash.....etc....just maybe.
Old May 15, 2005 | 11:42 AM
b18_crx's Avatar
Default Re: what is this, and do i need it? (crxtreme89h)
I THINK THE ONE YOU ARE TALKING ABOUT IS A GREENISH LOOKING BOX RIGHT? I BELEIVE THAT IS THE RELAY FOR THE COOLING FAN...............DON'T REMOVE!
Old May 15, 2005 | 11:53 AM
eda6's Avatar
Default Re: what is this, and do i need it? (b18_crx)
I believe it's the relay for the condenser fan. OK to remove if you don't have AC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">Follow the wires and see where they go. </TD></TR></TABLE>
if these wires go through the firewall with the AC lines that's what it is.
Old May 15, 2005 | 12:00 PM
user 98292739's Avatar
i have that..but its on both sides isnt it? i believe its a relay for your lights
Old May 15, 2005 | 12:16 PM
civhatch90's Avatar
i had the same question, i removed the ac system today and when i follow the wires to that black thing it leads me to the ac wiring harness, so i dont think it has anything to do with the lights
Old May 15, 2005 | 12:17 PM
civhatch90's Avatar
Default Re: (LoCoReX)
i think you are right
Old May 15, 2005 | 12:19 PM
civhatch90's Avatar
relay for condenser fan sounds reasonable to me
Old May 15, 2005 | 12:21 PM
lilneep16v's Avatar
Default Re: (civhatch90)
throw it out its for your ac
Old May 15, 2005 | 02:38 PM
Default Re: (lilneep16v)
the thing is i think only the 90-91s have them, my bros 88 doesnt have one. oh well ill see what happens when i remove it.
Old May 15, 2005 | 05:13 PM
bagpipe goatee's Avatar
my 89 has one, and it has a/c. does your brother's 88 have a/c? i'm sure that's what its for.
Old May 15, 2005 | 07:18 PM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
one is regular cooling fan, and the other is for AC
Old May 15, 2005 | 09:51 PM
FalkenSiR's Avatar
Default Re: what is this, and do i need it? (o-man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floss &raquo;</TD></TR><TR><TD CLASS="quote">the thing is i think only the 90-91s have them, my bros 88 doesnt have one. oh well ill see what happens when i remove it.</TD></TR></TABLE>
Actually my 88 has 3 relays and they all look the same. I know one is for the fan, and one is for the ac. Thats all i know
Old May 15, 2005 | 10:04 PM
TIRENECK's Avatar
Default Re: what is this, and do i need it? (fast88std)
just leave it, watch you cut it and you start to get shorts.
Old May 15, 2005 | 10:16 PM
DieMaster's Avatar
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">
Actually my 88 has 3 relays and they all look the same. I know one is for the fan, and one is for the ac. Thats all i know</TD></TR></TABLE>
there all for the ac. one is the A/C clutch relay, one is the condenser fan relay, and one is the AC diode with 3 wires( the 90 - 91 have it under the dash above the ECU).
BTW the relay mounted on the fender wall by the grounding thing is ur radiator fan. if u remove anything else KEEP THIS ONE.
neozero999
14
Oct 22, 2008 02:37 PM
Andryzzle
Jul 30, 2008 10:07 AM
asianalbutt
Sep 25, 2005 08:38 PM
. C h e n l a
Jan 14, 2004 12:58 PM
chief_rucka
Oct 10, 2002 12:39 PM
