How to change the psi on an Internal Wastegate
Hey I am sorry if this seems like a stupid question, but after searching and looking through the FI tech forum, I have not found what I need. I just want to know how to change the psi on an internal wastegate. Thanks
Usually with a boost controller, but sometimes you can lengthen the actuator arm if it is possible. If you do lengthen the actuator arm though, you'll only get a couple PSI out of it. Boost controller is probably your best option.
