What flywheel/clutch combo for B16 tranny in a B18c1 teg?
The 109 tooth or 112 tooth flywheel...I have a USDM starter.
Also do I buy a clutch/flywheel for a 1999-2001 Civic SI or Integra GSR 1994-2000.
Don't worry about the tiny little details. Any combination of pressure plates, clutch disks, and flywheels from a 99-00 Si and a 94-01 Integra are completely interchangable with each other.
that is the clutch/pressure plate I am running.
I am running an exedy chromoly flywheel though.
It has a good feel but the clutch chatters making a squeeking noise. This I have heard is common to ACT clutches.
not a bad combo, clutch/pressure plate combo really only needs to be stepped up if your adding power or driving more aggressive then the old set-up is intended to be.
Darn, I hate any noise in my car (whyi Dynamatted the entire car)...what about the Exedt Street Cluthces that are $200 cheaper than the ACT ones? Would IIt perform just as well?
The exedy out performs the act and is cheaper. I have the exedy and it requirs a agressive driver who loves lots of boost or big hp numbers from a all motor. ps no sqeeks from it either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinb »</TD></TR><TR><TD CLASS="quote">The exedy out performs the act and is cheaper. I have the exedy and it requirs a agressive driver who loves lots of boost or big hp numbers from a all motor. ps no sqeeks from it either</TD></TR></TABLE>
are you joking?
stop applying false information to people
act out performs exedy pressure plate wise
the disk i would have to say its all preference
i really like the CM kevlar disk but it doesnt fit in a act PP
but all in all ACT is best .. they do more R&D
and makes there PP from scratch not building from a stock part and adding fingers
and im running a fidanza aluminum F/W 7.5 lbs
ACT extreme PP
turbo clutch stage 3 disk (fiber tough) looks like a 10 puck LOL its the best i can explain it
my set up is a semi built gsr, turbo , nitrous vtec plate
10psi w/ 100 shot direct port
made 390hp
but personally im gonna get out of the single stage disk era
next time i build another beast it will be on a twin disk tilton with a dual mass F/W
are you joking?
ACT extreme PP
made 390hp
Dude what ever. I have had that crap. Come talk to me when you have had the hands on expereince. I have and the exedy is better. In 8 months you will need to replace your cheap crap act. Exedy is the better of the 2 there might be better but out of the 2 exedy dominates.
91 TEG
ys1 tranny
clutch master fly
exedy stage 3
unorthodox cam gears underdrives
t3 turbo
fmic
xs bov
turbonetics oil lines
maxsport rims
gforce ta's
tokico's
ground control limited's
equal leagnth header rev hard
35mm wastegate tial
ngk wires
ngk plugs
msd ignition sci
fmu plus way more. I know what I am talking about and I have the stuff to prove it
best et 10.98 @ 111 mph @ route 66 race way Joliet Illinos best track in the world
With stock internals tunes by Virginia speed
230,000 miles on engine still beating v8 all day with no problemo Daily driver homies
91 TEG
ys1 tranny
clutch master fly
exedy stage 3
t3 turbo
fmic
xs bov
maxsport rims
gforce ta's
tokico's
35mm wastegate tial
ngk wires
ngk plugs
msd ignition sci
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinb »</TD></TR><TR><TD CLASS="quote">Dude what ever. I have had that crap. Come talk to me when you have had the hands on expereince. I have and the exedy is better. In 8 months you will need to replace your cheap crap act. Exedy is the better of the 2 there might be better but out of the 2 exedy dominates.
91 TEG
ys1 tranny
clutch master fly
exedy stage 3
t3 turbo
fmic
xs bov
maxsport rims
gforce ta's
tokico's
35mm wastegate tial
ngk wires
ngk plugs
msd ignition sci
230,000 miles on engine still beating v8 all day with no problemo Daily driver homies</TD></TR></TABLE>
so your trying to tell me all that you just listed got you into the 10's? is that a 1/8 th mile? im guessing so,
you can talk all you want but concidering your trap time and trap speed i call BS on a 1/4 mile
show me your time slip and please dont grab someones else time slip from the track
the funny thing is i havent really seen a t3 turbo get into the 10's and still daily driven
specially in a 91 integ, you know what you listing your parts like that reminds me of those people that rolls around the street with the stickers but dont have the parts at all
my 94 integ is on a t3 and direct port nitrous and i for sure know im not in the tens
if your car is tuned.. why do you still have a fmu?
if you are going to try to speak some sense please come up with a better set up that
you remind me of this guy that came to my shop and said
he had a 98 cobra, racing a r34, he had a veilside kit, and he was clocked at 203 mph in 6th gear... now you tell me do i seemed impressed by your statement..
91 TEG
ys1 tranny
clutch master fly
exedy stage 3
t3 turbo
fmic
xs bov
maxsport rims
gforce ta's
tokico's
35mm wastegate tial
ngk wires
ngk plugs
msd ignition sci
bubblehead
May 31, 2006 02:39 AM
methanemotorworks
Feb 13, 2006 07:32 PM
