swap mount trouble
hey last night we put my b16 in my hatch i used az race and machine mounts.
now my questions wich mount do i need for the front crossmember the b series one is to far twords the front of the cat to get it to line up do i use a d series front mount or do i just not use one cause its really tight in there???
Most of the B-series mount kits only use 3 mounts....ie the the driver side,tranny side and the rear mount. the HCP uses all 4 mounts, and Place raceing has there crossmember with the 4th mount that they sell after......but for the most part you will not need that front mount in. I have the old place kit and only use 3 mounts and have since removed the plates that are welded to the cross member to have that much more room.....hth
Jockobo
11
Aug 31, 2005 08:17 PM
CRX MASE
May 5, 2005 08:32 PM
