Remove Si Logo from 00' civic si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manolo »</TD></TR><TR><TD CLASS="quote">I removed the Civic EX from mine and it left some gooey stuff on it, what should I use to remove it?</TD></TR></TABLE>
try goo-gone
try goo-gone
it's really easy to do...just get a pack of floss and rip off a piece and slowly move it back and forth behind the logo and it will eventually come off. do NOT use a razor blade, it's very easy to scratch your paint with. remove the residue with a little goo gone or goof off, but make sure you wipe it clean immediatly after with some water, the goo gone or goof off could leave a slight mark if you let it soak in.
to remove emblems just get some floss and a hair dryer. move the hair dryer over the emblem and heat it up then take the floss and slide it under the emblem to take it off. get a plastic razorblade and some multi purpose cleaner to get whatever stuff is left, if any. or if you have goo gone, you can use that too.
the more you heat up the adhesive the easier it will come off.
to remove the adhesive residue, wd-40 works well or paint thinner. Lacquer thinner might be too strong... nail polish remover is the same thing, I believe.
try using a blow dryer to heat up the compound then slowly scrape away at the emblem or stickers on your car. Then use some go be gone or some other compound to remove the residue. Works on my car no sol stickers at all except for the honda signs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeD718 »</TD></TR><TR><TD CLASS="quote">try goo-gone
easiest way to get it off
</TD></TR></TABLE>easiest way to get it off
soak it with some HOT water the when it soften up, just peel it off. It will leave some some sticky gooey stuff left.....then use GOO GONE to clean it up!!
All done!!
All done!!
WTF Razor blade...y not a flathead screwdriver or a chisel & hammer
gloo gone, goof off, paint thinner all works just dont let it sit to long, rub fast to get it off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDieM_ej1 »</TD></TR><TR><TD CLASS="quote">try rubbing compound. worked for me when i did it long time ago</TD></TR></TABLE>
Best Advice on here yet, I use it also because compound is very safe plus it shines you clear coat & it gets almost anything off ur whip
(buy heavy compound)
Best Advice on here yet, I use it also because compound is very safe plus it shines you clear coat & it gets almost anything off ur whip(buy heavy compound)
you can use a credit card to take off the emblem, and if there's any left sticky stuff, you can use "goo-gone" like everyone says or any adesive (sp.) remover. works like a charm!
Goo Gone
Goo Gone
who ever said using a razor is a dumb ***, i took off my civic badge...it left so much goo **** all over! i used goo gone....its not good enough. i microwaved a cup of water...made it extrememly hot....took a rag dipped it in hot water and started rubbing....after about 30 minutes of rubbing.... it clean and nice!
