easiest motor swap in a 88 crx
Old May 15, 2005 | 08:21 AM
phil9922's Avatar
Default easiest motor swap in a 88 crx
my friend just got an 88 crx and he wants me to help him swap a new motor into it. ive done swaps before but never in a honda. which motors will drop in without having to cut and weld, and what is his best option?
Old May 15, 2005 | 09:23 AM
crxkane's Avatar
Default Re: easiest motor swap in a 88 crx (phil9922)
check out
http://www.hasport.com
they will have some good info, and with there mounts you dont have to cut and weld anything...
also do a little searching, it will help you in the long run
Old May 15, 2005 | 10:08 AM
boosted_hatch_216's Avatar
Default Re: easiest motor swap in a 88 crx (crxkane)
any d series motor will drop right in. except the d16a1 or a8 or somethin like that. if you go vtec of course you have to wire up the vtec and get an obd0 - obd1 conversion or you could go with a chipped ps9 and stay obd0. the best bang for your buck would probably be the dohc zc. and what trim is the crx (I.E. dx hf si)? if its dx you need to do an mpfi swap. which involves a bit of wiring but its not too treacherous.
Old May 15, 2005 | 11:23 AM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phil9922 &raquo;</TD></TR><TR><TD CLASS="quote">which motors will drop in without having to cut and weld, and what is his best option?</TD></TR></TABLE>
Like you said without having to cut and weld, that leaves the H-series and K-series engines out of it. Which means you can swap in any b-series motor/tranny or D-series.
D-series: I would either go with the DOHC ZC, it drops right in and 130 hp right off the bat. Or, I personally like the D16Z6/D16Y8. You should run them obd-1 and you got vtec. All are 1.6 liters.
B-series: Little heavier than the D-series, but still a bolt in affair with the proper mounts (hasport). If you are strapped for cash, get a b18b or b18a (practically the same motor) and both are relitavely cheap and are great for turbos. Then there is the b16a, you should know what that engine is. Then you have the B18Cs. The GSR motor and the ITR, you will need atleast 4k to get those into a crx.
Also: if the crx is a DX only, then you need to convert to MPFI (multi-point fuel injection). If it is a Hf or Si, then you already have MPFI. And some D series and B series engines are obd-1, so in addition you will have to convert from obd 0 to obd 1
And search owns you. Like mentioned above.
Old May 15, 2005 | 11:48 AM
crxtreme89h's Avatar
Default Re: easiest motor swap in a 88 crx (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">
Like you said without having to cut and weld, that leaves the H-series and K-series engines out of it. Which means you can swap in any b-series motor/tranny or D-series.</TD></TR></TABLE>
B Series you have to cut the front mount off to fit.
Old May 15, 2005 | 12:33 PM
Hooch'n's Avatar
Default Re: easiest motor swap in a 88 crx (crxtreme89h)
DOHC ZC sounds cool, i think that is the project engine i'm going to roll with.
Old May 15, 2005 | 03:07 PM
isekiEF9's Avatar
any single cam!!!!
Old May 15, 2005 | 04:35 PM
bagpipe goatee's Avatar
you don't really have to cut the mount off, theres some exhaust manifolds/headers that clear it.
plus, it doesn't really matter if you cut it off, because its the crossmember, and not the actual car.
Old May 15, 2005 | 04:47 PM
.Thomas's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isekiEF9 &raquo;</TD></TR><TR><TD CLASS="quote">any single cam!!!!</TD></TR></TABLE>
F22A4??
Old May 15, 2005 | 04:48 PM
kid-crx's Avatar
Default Re: easiest motor swap in a 88 crx (Hooch'n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n &raquo;</TD></TR><TR><TD CLASS="quote">DOHC ZC sounds cool, i think that is the project engine i'm going to roll with. </TD></TR></TABLE>
good choice
Old May 15, 2005 | 06:02 PM
kidouninja's Avatar
I have a ZC in my hatch and it runs really well just do some research on common problems and dont expect to take it to high in the RPM range. As well aftermarket for these are really rare. I would suggest Z6 unless you can get ALOT of custom made parts. Z6 single pushes almost the same as the DOHC ZC but Z6 has more aftermarket support
joethejoeman
Feb 7, 2007 02:01 PM
deerek101
Feb 15, 2006 11:03 PM
-sir-
Apr 26, 2003 08:42 AM
