bulding up an LS head
i purchased a stock ls head that i want to build up. i'm going to put new springs, retainers,locks,valves,cams and cam gears in the head. i was planning on having a 3 angle valve job and porting the intake ports as well as the exhaust ports. this will be bolted to a STOCK B18B1 bottom end. my question is what would be the best parts to use? (i.e crower, skunk2, etc etc etc) will i need to chip my ecu if i put different cams and cam gears in? btw this will be a daily driver. any info would be greatly appriciated. thanks
I hate to be a dick, but if you search you will find your answer!
I personally use Crower components, and Ferrea Valves.
Check out this website, it is a community setup for nonvtecs. There are plenty of setups here to look at to give you an idea:
http://www.nonvtec.com
