a/f gauge install question (searched)
Old May 15, 2005 | 05:28 AM
Ben_si's Avatar
Default a/f gauge install question (searched)
I have no idea what wire on the ecu i need to hook my a/f guage up to. I know its purple to white but which one???
Old May 15, 2005 | 06:03 AM
Pioneer162's Avatar
Default Re: a/f gauge install question (Ben_si)
there is no way you could've searched and not found the answer, there are dozens of threads that contain 'ecu pinouts'......
Old May 15, 2005 | 06:50 AM
MikeD718's Avatar
Default Re: a/f gauge install question (Pioneer162)
its a solid white one. i think there are 2 to chose from so pick teh right one
Old May 15, 2005 | 08:14 AM
00supercivic's Avatar
if your hookin up that guage just splice into the wire harness on hte o2 sensor. its a white wire but use the sensor on the o2 sensor on the manifold/header what ever the case may be.
Old May 15, 2005 | 08:39 AM
SiDonny's Avatar
Default Re: a/f gauge install question (00supercivic)
on the ecu splice into the white wire on the third ecm/pcm connector to the right. it's going to be the one in the middle of that connector and make sure it's the thick dirty whiteish looking one beucase the other one is just a ground.
Old May 15, 2005 | 10:55 AM
Ben_si's Avatar
does the 00 si have wideband? cuz if not im selling the a/f gauge from what iv hurd
Old May 15, 2005 | 11:48 AM
Kamin's Avatar
Default Re: (Ben_si)
no it dosent have a wideband, if you want a cheap wideband look at AEM's UEGO setup
Old May 15, 2005 | 12:05 PM
egsleepercivic's Avatar
the guage is pretty useless without a wideband
perseverance
Jan 23, 2007 11:30 AM
BlUAc
Sep 24, 2006 10:20 AM
ToiletFetusSushi
Mar 2, 2004 11:09 AM
2000_Si_On_Air
Jul 6, 2002 06:35 PM
CiViCxR
13
Feb 13, 2002 12:46 PM
