Painting my Valve cover
So i am going to paint my valve cover to match the MR paint on my car, and i was wondering if i get it professonaly done at a body shop will it crack and peel from the heat, or will it be OK. I know there are plenty of valve cover threads but non-of them answered this question. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK »</TD></TR><TR><TD CLASS="quote">left mine stripped also</TD></TR></TABLE>
how do you strip the original crap off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eymnewdc4 »</TD></TR><TR><TD CLASS="quote">
how do you strip the original crap off?</TD></TR></TABLE>
AirCraft paint remover
if you're gonna leave it stripped, i've heard a good idea is to spray a couple coats of hi-temp clear coat on it so it doesnt corrode at all.
if you're gonna paint it, use primer, hi-temp paint and then hi-temp clear.
as for the lettering, you can use a thin layer of vaseline so you can just wipe it off once you're done painting; easier way to mask.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by optikal_blitz »</TD></TR><TR><TD CLASS="quote">AirCraft paint remover
as for the lettering, you can use a thin layer of vaseline so you can just wipe it off once you're done painting; easier way to mask.</TD></TR></TABLE>
im non vtec, but still i was gonna maybe not paint the letters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solar Stone »</TD></TR><TR><TD CLASS="quote">paint it camo green</TD></TR></TABLE>
i was thinking of something "different", but not that
im non vtec, but still i was gonna maybe not paint the letters.</TD></TR></TABLE>
vtec or not, i think when people paint over the lettering, it looks miserable.
if you're going for something different.. i'd say design a cool stencil.. or like a pattern you like (dual tone or tri tone) and spray it in crinkle paints of those colors.
I want to do that right now but my H22 Red top is just too damn pretty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by optikal_blitz »</TD></TR><TR><TD CLASS="quote">vtec or not, i think when people paint over the lettering, it looks miserable.
I want to do that right now but my H22 Red top is just too damn pretty.</TD></TR></TABLE>
as far as the letters ... ive heard someone say today that very fine sandpaper would take off the paint if painted over. just wanna know if that would or would not work before i paint
Yep that works, but from my experience, vaseline is much easier.
I'd say the most precise method would be to wait til everything dries and run a dremel with a sanding wheel accross the plane
no you don't, it's a must that you remove it (protect the vc gasket and be careful)
overspray will be everywhere and you wont be able to get a good angle/distance to paint evenly
it's probably possible, but i would never do it that way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by optikal_blitz »</TD></TR><TR><TD CLASS="quote">no you don't, it's a must that you remove it (protect the vc gasket and be careful)
it's probably possible, but i would never do it that way.</TD></TR></TABLE>
i didnt think it was a good idea. but i just wasnt sure. do you have to replace the gasket everytime? because my buddy has done his vc about 4 times in a very short period of time
you can reuse the gasket if it hasnt been damaged when you take it off.. just be careful with it.
after 4 times of taking it off and putting it back on i would suggest going to honda and picking up a new gasket.
$8.65 (Cover gasket)
$1.82/ea (Sparkplug gaskets)
http://www.HondaAutomotiveParts.com is great to order from.
:edit: haha sorry i don't know why i thought you had a prelude. but the prices are probably the same. different part numbers though.
