Where is the Daytime Running relay module?
Old May 14, 2005 | 09:43 PM
xtal's Avatar
Default Where is the Daytime Running relay module?
Having some problems locating the DRL module on a 96 EX accord, Canadian..
Basic directions are to look above the brake pedal for a grey box. There is indeed a grey box there, but it's got a sticker on it indicating it is the cruise control module. Perhaps they're the same thing?
Can someone please post a picture of what this module looks like? Honda wants $230 bucks to replace it, and I'm wanting to try the solder fix first.
Many thanks.
Old May 14, 2005 | 10:12 PM
TxTuner
Guest
Posts: n/a
Default Re: Where is the Daytime Running relay module? (xtal)
Why are you trying to find this? if you are simply trying to wire up your daytime running lights, there is an easier way.
Old May 15, 2005 | 07:47 AM
xtal's Avatar
Default Re: Where is the Daytime Running relay module? (TxTuner)
I need the DRL module repaired to pass safety inspection, I'm in Canada. No DRL, no drive car. It looks like it's just a matter of resoldering the joints, but I need to find the damn thing first.
If someone can post up what this module looks like, I can do up a howto on the repair..
Old May 15, 2005 | 06:59 PM
xtal's Avatar
If anyone cares.. here's how to fix it with pictures:
http://www.nyx.net/~smanley/hondadrlfix/
ashu9uf
Mar 15, 2011 09:25 PM
accordmatt
Aug 29, 2010 08:34 PM
ninja_xxx
Mar 29, 2009 01:28 PM
ddg2sailor
Aug 9, 2007 11:38 AM
