need help with wheel offset
hi, i have a chance to get a 16x8 wheel with a 38 offset. and i was wondering will i have any issues with this wheel. i've searched and the threads usually diccused either only the offset of how wide was the rim. but they never said anything about a 16x8 38 offset rims. thank you .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sublimnal »</TD></TR><TR><TD CLASS="quote">hi, i have a chance to get a 16x8 wheel with a 38 offset. and i was wondering will i have any issues with this wheel. i've searched and the threads usually diccused either only the offset of how wide was the rim. but they never said anything about a 16x8 38 offset rims. thank you . </TD></TR></TABLE>
It's going to be tight. It'd probably fit, if you don't mind doing a little (a lot?) of fender rolling.
My 16x7 with 205/45 tires, +38mm, were close all around but didn't rub at all with stock suspension. Lowered, the rears started catching the fender lip and the fronts too.
Are you lowered at all? Do you plan to be?
There's been a couple of 16x8 threads... most of the responses were about as little help as mine, but there's someone (at least 1 or 2) people in here with 16x8's.
Todd00
Jun 14, 2004 10:10 AM
