Newbie chick to crx
Alright boys! Have a 91 HF that I'm going to do a d16z6 swap into (and yea i know its just a 1.6L single overhead cam vtech) but I still have some questions and I suck at this forum stuff!
Okay, so do I need new front axles/hubs/brakes and what can I do that is bolt on that will increase ponies? Also, if I decided to go forced induction, do i supercharge or turbo? Is the HF tranny going to be worth keeping ( i know it's long geared) or should I get an SI tranny? Have short shifter I'm going to install.
Also, is runnin H&R race springs okay with stock shocks and struts and do I need a camber kit?
Thanks guys!
Thanks guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRedDevil »</TD></TR><TR><TD CLASS="quote">
you can use stock since your gonna be using another d series tranny , do bolt ons such as header , exhaust , and Cold air intakes for added ponies.
Ps. Girls with crx's are sexy
and i agree, girls that drive crx's are definately hot. wanna go for a ride?? sorry, i shouldn't have said that, but what do you expect when this place is 95% guys?? lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRedDevil »</TD></TR><TR><TD CLASS="quote">Alright boys! Have a 91 HF that I'm going to do a d16z6 swap into (and yea i know its just a 1.6L single overhead cam vtech) but I still have some questions and I suck at this forum stuff!
Thanks guys!
like the other guy said, you can use your axles, hubs, and brakes.
a supercharger doesn't have any lag but doesn't have as much hp potential as turbo. So it depends what your horsepower goal is before you can decide which is better.
Thanks guys!
</TD></TR></TABLE>like the other guy said, you can use your axles, hubs, and brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdriver89 »</TD></TR><TR><TD CLASS="quote">... the guy to girl ratio in here sucks</TD></TR></TABLE>
I'll sure say so... way too much wiener here.
1.6L single overhead cam vtech - Its Vtec not Vtech, vtech makes phones you noob
Okay, so do I need new front axles/hubs/brakes - No same thing
what can I do that is bolt on that will increase ponies? - IHE
Also, if I decided to go forced induction, do i supercharge or turbo? -whoaaa slow down
Is the HF tranny going to be worth keeping - No
Also, is runnin H&R race springs okay with stock shocks and struts and do I need a camber kit? wtf? Always run aftermarket struts with shorter springs or else you ride quality will be poor.
Oh yeah.. SEARCH
Oh yeah.. SEARCH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRedDevil »</TD></TR><TR><TD CLASS="quote">Is the HF tranny going to be worth keeping ( i know it's long geared) or should I get an SI tranny? </TD></TR></TABLE>
I like my HF Tranny...it's good with the Engine it's mated to.
Too bad Hondas have 0 Torque, cause that transmission is REALLY good at keeping your RPMs down, which would be awesome if you had a low-end Torque monster...[sigh]
I'd love to make a fast car which utilizes that transmission, but Honda goes HIGH RPM and low torque, so the Faster/higher you Rev, the better
And on the Axles, I was under the impression that because of the # of splines on the HFs Axles, that the axles ARE NOT interchangable with the other CRXs. When I swapped out my axles, it sucked, cause I had to get the "special" axles (On a side note, Honda doesn't reman HF Axles
), as most EVERY other axle was interchangeable, just not mine...
Otherwise, SWEET JESUS! But that I'd look into, cause I swear the HF has a different # of splines, and so you can only use HF axles in the HF tranny...
), as most EVERY other axle was interchangeable, just not mine...Otherwise, SWEET JESUS! But that I'd look into, cause I swear the HF has a different # of splines, and so you can only use HF axles in the HF tranny...
Oh yeah.. SEARCH
She said she was a newb chick... why did you even look at this if your just gonna belittle her? now thats screwed up... but im pretty screwed up right now so... never mind me.
Oh yeah.. SEARCH
Oh yah...and thanks for most of ur guys' help...although a select FEW seem to still have a problem with somebody with ***** trying to figure out a car, MY BAD! As for searchin...found some good stuff but everybody just posts stupid crap as replies so i don't get a lot of good info. Just tryin' to get sum sraight up answers here...sheesh! Now I know why my buddies told me not to get on here...freakin' guys and their bs.
Interesting bout the axles/hubs/breaks...a friend told me that all that had to be replaced to do my swap. I'll keep that in mind....anybodies opinion on Tokico (is that right?) shocks and struts?
Love For The Crx's,
Welcome to the site, The d16z6 isnt a bad first swap to do at all, i dont recommend it being that its an obd1 motor however it can still be done with a few simple tasks.
The HF Transmission really isnt good for anything, its not very strong at all and the long gears will not benefit much in your higher gears once your boosted. The hf knuckles need to be swapped for dx 5 spd or Si knuckles
hope that helps
mike
hope that helps
mike
I would throw together a homemade turbo kit for like $1000, don't go fully ghetto but buy some nice bling options while you are making the kit. That z6 boosted at like 7-8 psi would be fun to scoot around in.
P.S. Source a Si tranny, much better than the HF, can be had fairly cheap too
welcome.....i will just come out and say it....chick that dig their crx = sexy/badass chicks.
Congrats on the hf that's what i got......got any pics......of the car...(had to clear the air on that one)
l8z
l8z
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRedDevil »</TD></TR><TR><TD CLASS="quote">....anybodies opinion on Tokico (is that right?) shocks and struts?
Ive had Tokico Illumina on my rex for about 2 years. 5-way adj is plenty if you're gonna be using your car as a dd. I got the shocks + springs package and I think it was around 400 on ebay.. prolly best 400 bux I ever spent on my car.
</TD></TR></TABLE>Ive had Tokico Illumina on my rex for about 2 years. 5-way adj is plenty if you're gonna be using your car as a dd. I got the shocks + springs package and I think it was around 400 on ebay.. prolly best 400 bux I ever spent on my car.
if u plan on boosting it i would keep the long geared tranny...oh man today at the track homegirl whooped all the homies in her prelude..she was fine too....too bad they wouldnt let me pass tech for only having one lock on my hood..my ef woulda ate em all up
First of all, welcome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">you guys scare all teh ladies off </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drussell4801 »</TD></TR><TR><TD CLASS="quote">just over 10 posts and she's already discovered the level of ignorance on here.
jesus. EVERYONE CLICK THE BACK BUTTON IF A POST UPSETS YOU. </TD></TR></TABLE>
Exactley, some respect to ladies too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRedDevil »</TD></TR><TR><TD CLASS="quote">Also, if I decided to go forced induction, do i supercharge or turbo?</TD></TR></TABLE>
Turbo is way cheaper than supercharger, and you can set your engine's character easily with diffrent turbo setups. And ofcourse, turbo is more efficient.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRedDevil »</TD></TR><TR><TD CLASS="quote">Is the HF tranny going to be worth keeping ( i know it's long geared) or should I get an SI tranny?</TD></TR></TABLE>
I think you can keep, it. But you should get some other tranny, long ratios suck. In torqueless hondas mostly. :D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 turbo crx »</TD></TR><TR><TD CLASS="quote">Love For The Crx's,
hope that helps
mike</TD></TR></TABLE>
The hf knuckles can stay if your using another d series tranny, you only have to change when you go b series .... if you dont know your facts , please do not post.
hope that helps
