how to put on a 99-00 front end a 97 civic Help
Old May 14, 2005 | 06:46 PM
BeeEK9R's Avatar
Default how to put on a 99-00 front end a 97 civic Help
i need to know waht part i need and the instruction.
also is it a bolt on or your have to some costumizing
is it hard rate from 1easy - 5 hard
Old May 14, 2005 | 06:51 PM
integraXTC's Avatar
Default Re: how to put on a 99-00 front end a 97 civic Help (BeeEK9R)
if you do it properly it's pretty hard or at least time consuming. Dude search, there was a thread where the dudes did it w/o experience and they did a kick *** job (took like 3 or 4 guys) probably like a 4(1-5 5 being hard) Search the FAQ archive might be there,
Old May 14, 2005 | 07:29 PM
Civic4less's Avatar
SEARCH! Cmon man. You're new... you could of at least read the Forum Rules and Guidlines!
https://honda-tech.com/zerothread?id=1124618
https://honda-tech.com/zerothread?id=790135
https://honda-tech.com/zerothread?id=1007465
Just search before you ask a question on here. Chances are it's been covered.
Old May 14, 2005 | 08:06 PM
H22 QT's Avatar
You need to have brackets welded to make the front bumper fit with the stock crossmember.
Old May 17, 2005 | 06:56 PM
BeeEK9R's Avatar
Default Re: (H22 QT)
some people say u dont need the bracket say it just bolt on
Old May 17, 2005 | 06:59 PM
civictildeath's Avatar
Default Re: (BeeEK9R)
best one ive seen. shows it with rad support changed and down lower without it changed.
some people are **** about a 1/8 in bigger gap below the headlights
rawrjaay
Nov 4, 2010 01:53 PM
jdm_roger
13
Jun 25, 2010 10:37 PM
lrayford
May 12, 2009 03:40 PM
Normielove
14
Feb 22, 2005 12:15 AM
Built Beast
Oct 8, 2003 03:10 PM
