Help with code 3 and 41, can they be related?
Old May 14, 2005 | 05:18 PM
Used2beAb16's Avatar
Default Help with code 3 and 41, can they be related?
EM-1 with p28 conversion. car has ran fine with this setup for a long time, so its nothing to do with that. But just recently, my car threw code 41 for primary o2 sensor. I cleared the code and checked my 02 sensor and drove it, and now after about 200 miles its back on, but this time it is coupled with code 3. This is the code for the map sensor.
Can these be related or is my map going bad too? I am hoping that if i replace the o2 sensor it will eliminate the map code too, or is there something else wrong here??
Old May 14, 2005 | 05:24 PM
DeadVet's Avatar
Default Re: Help with code 3 and 41, can they be related? (Used2beAb16)
If anything i would think that the map sensor would be causing the o2 code not the other way around.
Old May 15, 2005 | 07:02 AM
Default Re: Help with code 3 and 41, can they be related? (1TurboHatch)
that would make more sense but earlier i had just the o2 code.
Old May 15, 2005 | 07:30 AM
DeadVet's Avatar
get a map sensor from a junkyard and see if that fixes both
Old May 15, 2005 | 08:12 AM
U know what map sensors work? its a b16 si tb.
d_boi_swag
Jul 5, 2009 12:14 PM
85crx509
10
Sep 18, 2008 08:28 PM
ILLICON3000
Aug 4, 2004 03:25 PM
