gauge cluster
Old May 14, 2005 | 03:26 PM
idriveadelsol7's Avatar
Default gauge cluster
i think there's some electrical problem with my del sol.
i notice when both my doors are open, there are no indicators on the gauge cluster that tells me my doors are open or they do not light up. but for everything else like the targa being unlocked, trunk, and rear window being open... the lights on the gauge work fine.
Old May 14, 2005 | 08:21 PM
Default Re: gauge cluster (idriveadelsol7)
anybody?
Old May 14, 2005 | 08:24 PM
TeamNextGenChris's Avatar
i've never paid much attention to a Del Sol-do they even have indicators for that?i know the Civics don't.if they do,check the pinswitches on the doors to see if they're broken or unhooked.does your dome light come on when the doors open?
Chris
Old May 14, 2005 | 08:28 PM
Default Re: gauge cluster (TeamNextGenChris)
yes... my dome light turns on when my doors open but the red light (on the gauge indicator) next to the door does not. i'm not sure if it does... just checking because the autobody might have screwed my electrical up.
Old May 14, 2005 | 08:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">just checking because the autobody might have screwed my electrical up.</TD></TR></TABLE>
what did they do to your car?did they work before?if the cluster does have indicators for the doors,i'd check the pinswitches and wiring.
Chris
Philip's Avatar
Years ago I had this problem on an 88 prelude. It seemed like the dome light was turned on via a different switch than the door open warning tale-tell light. Look near the hinge on the door and see if there is a switch that is pushed in (or somehow closed) when the door is shut. Push it in with your finger and see if you can get the light on the cluster to go off. The problem with the prelude was that the switch was going bad and I could make the light on the cluster go off when I activated the switch by hand, but not when the door was closed. You may just need to replace the switch. I doubt its a serious electrical problem.
Hope this helps.
Old May 15, 2005 | 01:53 AM
where exactly are the pinswitches and wiring for the door (gauge indicator)
Old May 15, 2005 | 06:01 AM
Pure Sol's Avatar
there isn't any indicator for a del sol to show the doors are lit. There are only leds for the trunk, targa, rear window.
Old May 15, 2005 | 10:11 AM
Default Re: gauge cluster (Pure Sol)
cools... appreciate it. just wanted to double check with a fellow del sol person
CTR_B
Mar 20, 2008 09:47 AM
MBlake55
May 25, 2006 06:24 PM
Slow_Boy
Aug 24, 2004 12:45 PM
integrasi
Jul 11, 2003 07:31 PM
743power
Apr 22, 2003 11:20 AM
