h22a1 lots of black smoke @ v-tec rev.. normal?
i told a friend to drive and stay behind me while i full throttle at high rev with vtec kicking it, he told me there where lots of black smoke coming out of the muffler pipe and it stink the sh*t out of him. I was wondering if it's normal because of vtec that eats alot of gas or it's just running too rich?
Ohh and 1 thing i'm confused, i just recently changed the t-belt and water pump 2 days ago. i remember the vtec kicks right @ 5,000, after the t-belt change it kicks @ 5,200. What did i do wrong here..? Did i misplaced the cam gears grooving or i didnt align it right when i put on t-belt? thanks
I believe our motors run a little on the rich side but the amount of smok eyou are talking about doesn't sound normal. I asked my friend to do the same thing and he said that he did not see ANY smoke coming from my exhaust when I was WOT.
My VTEC kicks in at 5200 on my rpm guage. Always has.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">I believe our motors run a little on the rich side</TD></TR></TABLE>
That's an understatement
I would let someone else drive your car and you check it out for yourself. It could be a combo of running rich and the rings/valve stem seals leaking some oil, as many Preludes do.
Unless it seems excessive, some smoke can be normal.
ooh yea i forgot, i got some oil around the spark plug thread. can that be the oil burning that cause more smoke? I don't understand how oil gets in there... i thought it'll be the o-rings but as i can see inside the hole to the spark plug housing..there are no signs of oil around the hole aside.. is there another o-rings just below the spark plug housing..?
There is a gasket between the head and the valve cover, actually at the bottom of the valve cover, that keeps oil from getting down into the spark plug wells. I would say the oil got to the plug threads from that gasket leaking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">
yeah, if we can call AFR 10.5 @ 7000 rpms like that
