y8 intake manifold with obd0 injectors and sensors.
I drive a 88 crx si with a y7/y8 mini me running on pm6 ecu and harness, summit racing rpm switch to activate vtec. My question is can I put a y8 intake manifold and still use all my obd0 sensors and injectors will everything bolt on and have no problems. thanks in advance.
might have a problem with the iacv(on the back of the intake). its not a big deal though, they sell obd1 sensors on ebay, and then its just a splice job. so yeah, you can do it no problem
the iacv on the back of the manifold is the same from one to another with their plugs .only difference is the size and where it mounts to , so get the y8 iacv and you will not have to worry about splicing.
