fuel not pumping
Old May 14, 2005 | 01:13 PM
p3lon21's Avatar
Default fuel not pumping
I turn off my car does not want to start anymore. were are the fuel pump relays and fuses
Old May 14, 2005 | 03:17 PM
nuttybumpo's Avatar
Default Re: fuel not pumping (pelon 1990 civic si)
i had a problem with my 89 si and found that the ground wire in the back under that hatch cover was bad i just took it off and ground to bare metal and reinstalled it car started right up. i work at a honda dealership in service and it only takes a few minutes. try that and if that doesn't work check the wires at the top of the gas tank they also like to corrode. let me know what happens
Old May 14, 2005 | 04:42 PM
p3lon21's Avatar
Default Re: fuel not pumping (nuttybumpo)
It was a fuse. First I had check the cover of the fuses and it didnt said nothing about a fuel pump. But i also had no spark. So i took one by one and second from the top was bad chage it and started rite up. thanks for the help.
My_EFsedan
Jun 30, 2009 03:49 PM
alscrx
Mar 5, 2009 03:07 PM
Hondas_Only
Feb 7, 2008 07:44 PM
01celica_gts
Jul 8, 2007 04:58 PM
hack3r
Apr 1, 2004 07:02 PM
