5 gen Tein S-Tech springs need camber kit?
I searched but found nothing. I just installed Tein S-Tech springs with KYB AGX shocks. The spec is -1.5 front, -1.3 rear. I just want to know if any 5 gen here with S-Tech springs run with or without camber kit? Both the front and the rear look like they have a lot of negative camber to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_roller »</TD></TR><TR><TD CLASS="quote">doesn't NEED camber, just get alignment to fix your toe. </TD></TR></TABLE>
Do you have these springs? It is funny that after I installed the springs, my alignment was still perfect. I don't have any problem with alignment, but I do have a lot of negative camber.
yes i have those springs. I didn't get as much negative camber as you are portraying tho. I had -1.5'', it isn't bad so i didn't bother with the camber kit. Just needed to fix the toe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_roller »</TD></TR><TR><TD CLASS="quote">yes i have those springs. I didn't get as much negative camber as you are portraying tho. I had -1.5'', it isn't bad so i didn't bother with the camber kit. Just needed to fix the toe</TD></TR></TABLE>
What shocks are you running? How you feel about S-tech springs?
RicedREX
Feb 28, 2004 07:19 AM
