Is my Crx setup any good? check it out
Old May 14, 2005 | 10:49 AM
Wasabithegosu's Avatar
Default Is my Crx setup any good? check it out
I was wondering if my setup is any good. Here's what i have so far. I wanted an all-motor setup while being on a tight budget. How much Hp/Tq can i expect? How fast will it prolly run? Im running with full A/C and heater w/full interior.
1990 Honda Crx Si
JDM B16A
11.5 JE pistons
Eagle H-beam rods w/ARP bolts
Skunk2 Stage 2 Cams with racing retainers and valve springs
Ferrea valves
AEM tru-time cam gears
Stage 1 port and polished Head
Integra Type-R intake Manifold
Edelbrock JG 65mm throttle body
RC 310cc injectors
Walbro 255lph fuel pump
Crane cams 11mm Firewire spark plug wire set
MSD SCI-L ignition control
Exedy Stage 1 Racing clutch
11lb chromoly flywheel
Weapon-R Dragon intake w/Ram air kit
2.5" 4-1 headers
2.5" Catco Cat Converter
2.5" Catback system w/N1 muffler 4"tip
Hondata s200
Koyo High FLow radiator
Tokico HP shocks
Bomz racing coil overs
Stock CRX Si 14" rims w/Yokohoma ES100 tires
Old May 14, 2005 | 11:05 AM
riceisnicenv's Avatar
Default Re: Is my Crx setup any good? check it out (Wasabithegosu)
you'll run anywhere between a 14.3 and 18.9... depends on your RaCiNg SkIlLz
Old May 14, 2005 | 11:09 AM
kaoss_11's Avatar
B A N N E D
clean and reliable but i would squeeze on that bitch with slicks if you want 12's 50 shot should be good
Default Re: Is my Crx setup any good? check it out (riceisnicenv)
14.3??? are you serious? with all the **** i got into it? i calculated about 225hp to the wheels.
Old May 14, 2005 | 11:10 AM
Default Re: (kaoss_11)
cant run NOS on those pistons. 11.5:1 is a lil warm for NOS rite?
Old May 14, 2005 | 11:17 AM
donuttes's Avatar
isn't it a little late to be asking if it's good or not?
wrXtian's Avatar
Default Re: (Wasabithegosu)
what are your dyno numbers... 225 seems too far fetched.
Old May 14, 2005 | 11:20 AM
Default Re: (D16A6_HF)
havent dynoed or anything yet. i still need to take it to the shop to get the Hondata programed. maybe its closer to 200 to the wheels
Old May 14, 2005 | 11:27 AM
wrXtian's Avatar
yeah get that hondata tuned it will help a lot.. i'm guessing a 190-200 ballpark figure..
Old May 14, 2005 | 11:53 AM
kaoss_11's Avatar
B A N N E D
i agree
Old May 14, 2005 | 12:07 PM
channy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wasabithegosu &raquo;</TD></TR><TR><TD CLASS="quote">14.3??? are you serious? with all the **** i got into it? i calculated about 225hp to the wheels. </TD></TR></TABLE>
lol calculated 225whp...
Try using a dyno they are better at math then you. You might have your expectations way to high though. Non the less still should be a fast car.
Old May 14, 2005 | 12:53 PM
user 98292739's Avatar
im guessing 183
Old May 14, 2005 | 12:57 PM
Bjorn20's Avatar
what does the hondata do that makes it so special? cause i eventually am getting one, but i need my b series first.
Old May 14, 2005 | 01:33 PM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wasabithegosu &raquo;</TD></TR><TR><TD CLASS="quote">cant run NOS on those pistons. 11.5:1 is a lil warm for NOS rite?</TD></TR></TABLE>
NOS has nothing to do with heat. it actually makes the engine run cooler when U spray as long as you have enough fuel. if you run lean of course it will run hotter.
Old May 14, 2005 | 02:13 PM
Burlyirishdude's Avatar
Default Re: (88crxhfb16)
i would think you would run faster then 14.3.......all in the driver....Buit still full interior in an SI, should break the 13 mark.....with all the fatty stuff in your car....
Old May 14, 2005 | 02:59 PM
Stefndogg's Avatar
Default Re: (Burlyirishdude)
ya u could def break into the 13's w/ that setup....prob pushing about 180-200whp on good tune
Old May 14, 2005 | 06:07 PM
surrealcivic17's Avatar
Default Re: (Stefndogg)
Dude riceisnice posted this today on my computer, and pulled the 14.3 outta his butt just to be funny, so you are gunna buy a hondata ecu even though you dont know what it does?! fishy
Old May 14, 2005 | 06:35 PM
NACvicSi's Avatar
That and he thought nitrous (which he says NOS) would be bad for high compression. When you order the pistons it even says with them they are good for nitrous. I call BS
Old May 14, 2005 | 08:37 PM
kid-crx's Avatar
nice setup gl with whatever ur going to be putting out
Old May 14, 2005 | 09:35 PM
hahagasdcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wasabithegosu &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if my setup is any good. Here's what i have so far. I wanted an all-motor setup while being on a tight budget. How much Hp/Tq can i expect? How fast will it prolly run? Im running with full A/C and heater w/full interior.
1990 Honda Crx Si
JDM B16A
11.5 JE pistons
Ferrea valves
RC 310cc injectors
2.5" 4-1 headers
Hondata s200
Tokico HP shocks
Stock CRX Si 14" rims w/Yokohoma ES100 tires</TD></TR></TABLE>
Thats a pretty big tight budget.
Get your motor and everything first, then do the swap. Save your money and buy **** over time. That way you will learn everything you need(or dont) to know over that time.
Old May 14, 2005 | 09:51 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">
NOS has nothing to do with heat. it actually makes the engine run cooler when U spray as long as you have enough fuel. if you run lean of course it will run hotter.</TD></TR></TABLE>
hehehhe
Old May 15, 2005 | 12:51 AM
jisu009's Avatar
Default Re: (drussell4801)
175hp 110tq
have fun.
Old May 15, 2005 | 04:32 PM
check out http://www.jepistons.com. it says my pistons arent meant for nitrous. also, i do know what hondata is for. check the name of the person who posted it.
Old May 15, 2005 | 04:50 PM
NACvicSi's Avatar
wow they actually do say not for nitrous. I wonder why?
Old May 15, 2005 | 05:01 PM
Default Re: (NACvicSi)
what more can i do to improve performance w/o having to get forced-induction/or stripping the car? and without having to use slicks? street racing is fun too...
