camber/wobble questions...
Ok when im driving my steering wheel shakes a lil, i know this can be caused by a few things:
alignment
balancing
ball joints
My car is lowered and i have no camber kit so technically i cant get it aligned properly right? I want to get the ominpower camber kit, i will install it myself, and i know it replaces the front upper ball joint but will i need to also purchase a front lower seperatly from the kit?
Also what is a reasonable price to pay a shop to adjust the alignment, camber, and balnce the wheels?
Thanks fo the info~
alignment
balancing
ball joints
Thanks fo the info~
That's not entirely true. The camber can't be adjusted but the toe can and that sounds like it could be your problem. also ask the alignment shop how off you camber is so you know what kit would be best for you. an alignment is like 70-80 bucks.
