major problems after new engine install
Old May 14, 2005 | 09:27 AM
Crasian's Avatar
Default major problems after new engine install
okay, i put a d16z6 in my coupe, should have been a fairly simple enough swap right, well rite now i am having a major problem. Once it starts reving past 3000 rpm it becomes very boggy and wont really go any higher then 4000 rpm, does anyone know what could be causing this? I just got rid of all my cel codes... So i dunno what is left to do.
SOMEONE PLEASE HELP ME
oh yeah, its a 93 d16z6 in a 93 civic dx coupe
Old May 14, 2005 | 09:32 AM
HitEm'Up's Avatar
Default Re: major problems after new engine install (FarOutCoupe)
What ECU?
Old May 14, 2005 | 09:39 AM
civicxpress's Avatar
Default Re: major problems after new engine install (HitEm'Up)
may be maf sensor
Old May 14, 2005 | 09:44 AM
Crasian's Avatar
its a stock p28 ecu that i know was working properly because i just took it out of my old car and whats a maf sensor?
Old May 14, 2005 | 10:41 AM
dumpedeg6's Avatar
Default Re: (FarOutCoupe)
i have the same **** happen to me, need to change the ecu to p28 its gives off better ignition and more fuel...plus vtec
Old May 14, 2005 | 10:44 AM
JDMisGOOD's Avatar
Default Re: (dumpedeg6)
If the ECU is a P28...check the MAP sensor
Old May 14, 2005 | 12:43 PM
civic94B18B1's Avatar
If you had a non-vtec before than you need to swap out the old ECU for a vtec one. If that's not it than i suggest you get the manual and learn more about the car and it's various sensors before you go to swapping **** around.
Old May 14, 2005 | 01:14 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: major problems after new engine install (civic94B18B1)
make sure the tps and map sensor and iacv is wired up correctly and not mixed together.
Make sure you wire up the vtec solenoid, ground it, and also wire up the 4 wire oxygen sensor
Old May 14, 2005 | 01:19 PM
GZR4DR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic94B18B1 &raquo;</TD></TR><TR><TD CLASS="quote">If you had a non-vtec before than you need to swap out the old ECU for a vtec one. If that's not it than i suggest you get the manual and learn more about the car and it's various sensors before you go to swapping **** around. </TD></TR></TABLE>
It's an engine swap, not brain surgery......
If you actually read what he posted you would see he is using a P28 ecu which is a VTEC ecu.....
Check the map/TPS sensors, also check any engine codes that you have.
Old May 14, 2005 | 02:56 PM
ruckussss's Avatar
Default Re: major problems after new engine install (GZR4DR)
id check the fuel system,tps,map sensor and o2 sensor....it probly one of those
Old May 14, 2005 | 04:44 PM
Antilag's Avatar
Default Re: major problems after new engine install (ruckussss)
I have seen time and time again when people plugged the tps and map backwards since they have the same plug. just check that.
Old May 14, 2005 | 04:55 PM
emoney9's Avatar
Default Re: major problems after new engine install (9sech22civic)
yeah a grip of people switch those plugs all the time...you might want to check a couple of your vacuume hoses too
Old May 14, 2005 | 05:07 PM
Lmgrcivic's Avatar
Default Re: major problems after new engine install (emoney9)
does it do it as soon as you start the car or does it only do it after the car has warmed up. if so you might be gettin to much fuel pressure might sound stupid but I had this same problem and I had to switch injectors but that was the problem was to much and it bogged the car down but also check the map sensor and the tps sensors also
Old May 15, 2005 | 07:08 AM
Crasian's Avatar
Default Re: major problems after new engine install (Lmgrcivic)
it does it all the time from when i first start the car up, i am gonna check the tps and map sensor if they have the same plug because i had to put this engine harness onto my new engine so i may jhave made a mistake doing so. also, i installed new fuel injectors too
Old May 15, 2005 | 08:00 AM
ILLICON5000's Avatar
Default Re: major problems after new engine install (civicxpress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicxpress &raquo;</TD></TR><TR><TD CLASS="quote">may be maf sensor</TD></TR></TABLE>
couldn't be, maf doesn't come on hondas.
Sounds like your TPS sensor. but on a stretch I'd check my distributor (TDC sensor) and the Crank fluctuation sensor.
Old May 16, 2005 | 06:22 PM
Crasian's Avatar
and how do i check them?
Update:
checked timing (its fine)
changed spark plugs
changed fuel pump
changed injectors
inpected hoses for vacuum leaks
got rid of all engine codes
changed fuel filter
oh boy, why do i get all these problems happneing to me
Old May 17, 2005 | 10:58 AM
Crasian's Avatar
Old May 17, 2005 | 02:59 PM
crvtecwidebody's Avatar
I see this alot. If you took the throttle position sensor(tps) from a different throttle body and put it on a newer throttlebody you have to adj. the tps so the ecu gets the right signal 0.5 volts closed and 5.0 volts wide open from the middle wire on the tps plug.
some dx's have manifold absolute pressure(map) sensor plugs come off of the chassis wire harness out of the firewall as a single plug.
If you are useing the p28 vtec engine wireing harness do not use the map plug off of the engine wireing harness.you have the firewall map harness if you have the extra plug comeing out from under the battery.
Vtec wires being disconnected won't affect the problems you are having.
I don't think it is your idle air control (iac) valve. Because you say it happens even during acceleration.
my II cents.
Old May 18, 2005 | 02:08 PM
Crasian's Avatar
Default Re: (crvtecwidebody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtecwidebody &raquo;</TD></TR><TR><TD CLASS="quote">I see this alot. If you took the throttle position sensor(tps) from a different throttle body and put it on a newer throttlebody you have to adj. the tps so the ecu gets the right signal 0.5 volts closed and 5.0 volts wide open from the middle wire on the tps plug.
my II cents.</TD></TR></TABLE>
thanks alot crvtecwidebody, i tried the map sensor thing and my car does have the map sensor connector coming from under the battery, i did what u said and it didnt change a thing. :S I dont kn ow how to check the tps but i dont think thats the problem anyways. UGHHHHHHHH I HATE THIS CAR
Old May 18, 2005 | 02:38 PM
Crasian's Avatar
oh yeah, forgot to mention i am also getting a code 43
Old May 18, 2005 | 03:37 PM
fuel supply code 43. If you had a air/fuel ratio gauge and a fuel pressure gauge you could check that for confirmation.
If your tps is miscalibrated it can lean/rich you out and mess with the timing advancement in a bad way.
Is 43 the only code you have thrown since the swap. a little more info would help me know what to check.
Old May 18, 2005 | 03:42 PM
Crasian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtecwidebody &raquo;</TD></TR><TR><TD CLASS="quote">fuel supply code 43. If you had a air/fuel ratio gauge and a fuel pressure gauge you could check that for confirmation.
Is 43 the only code you have thrown since the swap. a little more info would help me know what to check.</TD></TR></TABLE>
hey, i checked the spark plugs and my buddy said they look fine so iu dont think its running lean or rich. the only engine codes ive gotten is ones for my vtec not being wired up (fixed that since) and i got an o2 sensor code at first but it went away. Do u have msn man? if so add me kieran3000@hotmail.com, i could really use your help
Old May 18, 2005 | 09:32 PM
Crasian's Avatar
bump, please help guys, i wanna drive my car faster then 80km/h :S
Old May 19, 2005 | 07:14 AM
Crasian's Avatar
Old May 19, 2005 | 08:44 AM
spockeg's Avatar
make sure that the tps is in the slot & has the right volts
