Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What brake lines to use...
Old May 14, 2005 | 08:56 AM
kndaqikEG's Avatar
Default What brake lines to use...
I think this is the wrong forum but knowledge always prevails. What brake lines should I be using for my EG with GSR brakes? I got some for an EGsi with rear disc. I hope they are the correct ones. TIA and I hope I dont get booted, I just want good info. Also are there any downfalls to using higher temp brake fluid during the daily driving portion of your street/ race car use? Thanks again.
Old May 14, 2005 | 10:04 AM
Circuit Star-29's Avatar
Default Re: What brake lines to use... (kndaqikEG)
Use the Gsr rear brake lines or any Honda/Acura rear brake line.
Old May 14, 2005 | 10:56 AM
Vandemar's Avatar
Drum rears use a different fitting than discs, so you'll need rear soft lines intended for a car with discs.
Higher-temp brake fluids tend to absorb moisture more quickly, so you should flush/replace them more often. And it's more expensive, but otherwise there's no reason not to use high-temp fluid for daily driving.
project93cpe
Dec 4, 2007 05:20 AM
PINKS
Oct 18, 2007 04:25 PM
JDM_SOHC
Jul 16, 2007 05:38 PM
servion
Feb 26, 2004 05:07 PM
