Wheres the MAP sensor on an OBD0 vehicle 89 CRX HF
Old May 14, 2005 | 08:38 AM
drewboy's Avatar
Default Wheres the MAP sensor on an OBD0 vehicle 89 CRX HF
Im receiving a TPS error as well as MAP sensor error on my DOHC ZC. I received the MAP sensor error as soon as I tryed swapping out the ZC tps with a Z6 tps. Doesnt look like they are compatible as Im still receiving the error and the z6 gasket is way too large.
My question is where is the MAP sensor on a 89 CRX HF?
Old May 14, 2005 | 08:50 AM
drewboy's Avatar
bumpppppple bubbles..
Old May 14, 2005 | 09:07 AM
CRX_Control's Avatar
Default Re: (drewboy)
its right next to the charcoal casnister on the firewall . Look for the thing with like 4 or so vacume lines comming out of it .
Old May 14, 2005 | 09:11 AM
Default Re: (CRX_Control)
better yet , this post was recently made and has info on where it is and what it looks like https://honda-tech.com/zerothread?id=1244399
Old May 14, 2005 | 09:18 AM
88crxhfb16's Avatar
Default Re: Wheres the MAP sensor on an OBD0 vehicle 89 CRX HF (drewboy)
just went through this myself. I have an 88 HF should be the same and yes they are completely different from dx and si. here you go
and here we go:
Old May 14, 2005 | 09:20 AM
drewboy's Avatar
awesome, thanks bud. to be honest, i dont think i have a map sensor on my firewall or throttle body. Ill go give it a better look in a few hours.
88crxhfb16's Avatar
i used a Blox type B bypass, and kept a standard b16 throttle body not the one with a mapsensor on it. cause it dont fit my block. I can post a pic of it if U want. let me know.
Old May 14, 2005 | 09:22 AM
88crxhfb16's Avatar
Default Re: (88crxhfb16)
if you have an HF, that should be it, it will say denso on it. unless when U had your swap done they ripped it out.
drewboy's Avatar
ok 88crxhfb16,
that looks alot like what I have. I didnt start receving the error till i tryed replacing tps sensor, any suggestions?
Old May 14, 2005 | 09:25 AM
drewboy's Avatar
yes please post a pic, thankyou
Old May 14, 2005 | 09:51 AM
drewboy's Avatar
heres what my engine bay looks like. I assume my MAP sensor is under that black box?
Old May 14, 2005 | 09:58 AM
88crxhfb16's Avatar
what do mean, what sensor did you try to replace? the one on the firewall? that my pic points to?
also it wont be untill tonight till I can get u some more pics up.
check back
later
Old May 14, 2005 | 10:01 AM
88crxhfb16's Avatar
yeah, remove that black box and it will look exactly like my pics. also you definately have a different Manifold than I got.
Old May 14, 2005 | 10:11 AM
drewboy's Avatar
i tryed replacing the TPS sensor with a Z6 one, no luck, then I got the MAP sensor error after taking the z6 sensor back off.
So I guess I'll go looking aaround in junkyards today.
Jordan_l
Sep 9, 2008 11:23 PM
CRX831
Mar 31, 2007 05:14 PM
florinels
Jan 24, 2004 07:10 PM
iwouldHITit
Feb 16, 2003 04:04 AM
