Can a rear sway bar affect 60' times?
Old Feb 4, 2002 | 07:27 PM
HX_Guy's Avatar
Default Can a rear sway bar affect 60' times?
Rear squat is bad for 60' times (traction).
A sway bar connects the rear control arms to the frame correct? Therefore making the rear suspension stiffer when you push down on the rear right?
Im wondering because I took mine off for weight savings, but might it hurt me in other way?
Old Feb 4, 2002 | 07:32 PM
jgale's Avatar
Default Re: Can a rear sway bar affect 60' times? (HX_Guy)
my belief is that a sway bar only effects the movement of one side against the other, not in the case of both compressing equally at the same time(that would be your spring rates). For drag, the a stiffer rear spring rate would control squat.
just my $.02
[Modified by jgale, 11:33 PM 2/4/2002]
Old Feb 4, 2002 | 07:34 PM
HX_Guy's Avatar
Default Re: Can a rear sway bar affect 60' times? (jgale)
Yes, but it appears that the rear sway bar actually kept the suspension a little compressed. When I unbolted it from the frame, the rear suspension dropped a couple inches.
Hmm
Warren's Avatar
Wrong-Way Wang
no.
Warren
Old Feb 4, 2002 | 08:40 PM
BoM's Avatar
BoM
Default Re: Can a rear sway bar affect 60' times? (Warren)
of course it affects it
the thing is soo heavy!
Old Feb 4, 2002 | 08:47 PM
MrBite's Avatar
The swaybar's only purpose is to connect the opposite sides of the suspension to each other (there aren't any solid connections to the frame, only the bushings), so that when one side compresses, the other side does too (same for decompression). So, this shouldn't affect front-back transfer at all (or at least nothing noticeable).
Edit: Maybe if you had crazy torque that lifted one side of the car up at launch on a RWD car...
[Modified by MrBite, 12:48 AM 2/5/2002]
Old Feb 5, 2002 | 03:17 AM
JohnnyBoy's Avatar
Default Re: Can a rear sway bar affect 60' times? (MrBite)
Only for side to side...not front to back.
Old Feb 5, 2002 | 03:24 AM
Willard's Avatar
have your rear suspension checked.
answer to your question.... NO
Will
Old Feb 5, 2002 | 04:50 AM
Mista Bone's Avatar
D Tranny Guru
no effect...........before/after
even with ungreased bushings.
Old Feb 5, 2002 | 05:09 AM
Lip's Avatar
Lip
Default Re: Can a rear sway bar affect 60' times? (Mista Bone)
what rear sway bar? i hoped that answered your question.
Old Feb 5, 2002 | 06:08 AM
HX_Guy's Avatar
Default Re: Can a rear sway bar affect 60' times? (Lip)
Its a suspension techniques swat bar
the bushing got annoying as hell (squeeked) and I took it off for weight savings. Maybe it was the bushings that caused the suspension to drop a couple inches? Who knows...but handling without it doesnt really seem any worse, the ride actually seems nicer, quieter and more "plush"
Old Feb 5, 2002 | 06:29 AM
JPP's Avatar
JPP
If I understad correctly you took the bushings off the sway bar. If so the sway bar is not doing it's job. You need the bushings as fix pivot points for the sway bar to have any effect from one side to the other. I would strongly recommend that you put them back on.
EDIT: or maybe you meant that you took the sway bar off (and not just the bushings) for weight reduction??... Oh... I just reread your first post and you meant the sway bar... never mind then.
[Modified by JPP, 10:33 AM 2/5/2002]
[Modified by JPP, 10:36 AM 2/5/2002]
Old Feb 5, 2002 | 06:40 AM
HX_Guy's Avatar
Default Re: Can a rear sway bar affect 60' times? (JPP)
Heh...damn this thing is pretty light. Just weighed it on the FedEx scale at works and it cme in at 9.10 LBS w/ bushing and hardware.
Old Feb 5, 2002 | 07:03 AM
TypeR0149's Avatar
gotta love the sarcasim
Old Feb 5, 2002 | 07:15 AM
HX_Guy's Avatar
Default Re: Can a rear sway bar affect 60' times? (Vegeta)
Hahaha...doh! I was a little slow on that one..finally got whats he's saying
Old Feb 5, 2002 | 07:31 AM
1GreyTeg's Avatar
Yeah, but alot of the new one's probably don't even know what he has or what it runs...
what rear sway bar? i hoped that answered your question. I hope so too!
A.
tamadrumr88
20
Jul 19, 2008 07:31 AM
AamirCWITR
May 12, 2007 04:06 PM
envee
Suspension & Brakes
Apr 17, 2007 09:26 PM
mr_mbuna
Aug 30, 2002 12:39 PM
