Wiring?
If the hatch is si, you need a obd0-1 jumper if you are going to do it right. Then wire in the sensors that are labled on the harness. If its a dpfi hatch, you need a mpfi swap on the wiring.
http://www.rywire.com for all your needs.
If you are a do it yourselfer, simply mod the harness accordingly, and your set. http://www.droppedcrxsi.com might help out a lil.
