For Those Switching to Double Core Radiators (Single Wide Core)
Old May 14, 2005 | 01:56 AM
cpforyou's Avatar
Default For Those Switching to Double Core Radiators (Single Wide Core)
Allright guys, a stock Civic Radiator is 5/8" Thick Copper Core.
Mine just cracked so it's time to replace it. Which do you guys think is better?
A. All Aluminum Radiator w/ one wide 1" Core
B. All Aluminum Radiator w/ double core (two 1/2" Cores)
If you add it up, it's still adds up to one inch, so it's the same right?
Old May 14, 2005 | 03:22 AM
Morning Call's Avatar
both will work fine
matter of your choice really
Old May 14, 2005 | 06:13 AM
97civicdx's Avatar
Default Re: For Those Switching to Double Core Radiators (cpforyou)
They say the dual core is the better choice if you are planning a b series swap.
Old May 14, 2005 | 01:56 PM
cpforyou's Avatar
Default Re: For Those Switching to Double Core Radiators (97civicdx)
What are you guys basing this one?
If you think about it, a 1" Wide Core Provides less restriction of the water.
But a dual 1/2" core have more weaves which might suggest that it allows the air cool it better?
So I'm wondering which is better?
More restriction and better heat dissapation.
or Less Water Restriction but sligtly worser heat dissapation.
Tootsie7944
Feb 9, 2012 01:56 PM
cpforyou
May 13, 2005 05:44 PM
Importracer_001
Welding / Fabrication
21
Apr 20, 2005 05:37 AM
MikeTV
Dec 22, 2004 06:31 PM
