95 Integra A6 retrofit
Here are some pictures of my retrofit. These are with aftermarket 8000K bulbs so the light output is not that great but I have some 4100K OEM's on the way.
hey peja43916, does the colors on your cutoff is as dark as it suppose to be? I'm asking you this because I did an A6 retrofit into my integra too. However, the blue and purple colors on my cutoff is not very dark as it suppose to be. I guess that is because my lens are old. Do you have the same problem? If yes, did you solve it and if yes, how did you do it or you just left it the way it is?
thanks
thanks
here are pictures of my cutoff with OEM 4100K bulbs. It all looks alot better now but I need to try to get rid of some glare as you can see in the picture. I found that it is coming from the light reflecting off of my bumper right in front of the headlight housing. I tried putting some tape over that part of my bumper to make it dull so the light wouldn't reflect off of there and the glare went away. Anyone have any ideas on other ways to get rid of this glare?
